Can somone take look at my log and tell me if there's anything amiss
Ressegger
My log looks alot diffrent then normal and I saw something about user nobody so dropping root privileges. So hoping someone that knows more then me can take a quick look and tell me if I should be conserned.
  • syslog.txt
What about it is different than normal? We don't know what is normal for you. There's nothing in the log about user nobody.
EDIT: It looks much the same as the log file you posted on 3rd September.
How could you notice anything with all those firewall logs cluttering your syslog? :rolleyes:
Or is that the problem? You have Log dropped packets enabled in firewall but you don’t know why?
1) Your traffic monitoring database is missing:
Sep 27 22:17:44 rstats[1031]: Problem loading /mnt/sda1/Traffic monitor/tomato_rstats_049226814c68.gz. Still trying...
2) Something on your LAN is generating a LOT of separate connections, overwhelming your router:
Sep 27 22:17:53 kernel: nf_conntrack: expectation table full
3) Don't enable logging of dropped connection attempts unless troubleshooting something - this is overloading your router and flooding your log.
Sep 27 22:20:37 kernel: DROP IN=eth0 OUT= M
Heres a screen grab of the thing about user nobody.
Thank you merlin I guess that shows my newbie - ism but if you don't mind I had one more that looked very odd to me but maybee it's not, though if you or anyone else would mind taking a peek at it because in The log I saw some odd stuff like deep green modual or deep green ring installing I think as well as the date changing back to March for a bit and then it seemed like it was installing packages so I'm abit worried specially as this happened right after a reboot. And it's disconnected at the moment and so Im a bit nervous about reconnecting it.
  • syslog (7).txt
The May datestamp indicate that the router hasn`t configured its clock over NTP yet.
looks like your router rebooted right after failing to load that log merlin mentioned. the deep green mode is normal I believe. When the router first boots it will show a different date till the time sync kicks in as merlin stated.
