Dismiss Notice
Welcome To SNBForums
Cannot logon to RT-N66U.
Discussion in 'ASUS N Routers & Adapters' started by Synomenon, Jun 25, 2012.
  1. Synomenon
    Synomenon Regular Contributor
    Jun 23, 2012
    65
    Been having this issue with the RT-N66U. Even though I've pressed the "Logout" button after changing settings, the next time I try to access the RT-N66U (192.168.1.1), I get a message that says:
    Anyone know how to fix this?
  2. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,277
    Canada
    Connect through telnet, and run the following commands:
    If you can't telnet in, you will have to power cycle your router.
  3. Synomenon
    Jun 23, 2012
    65
    I should probably Google how to "connect through telnet", but what exactly do those commands do?
  4. RMerlin
    Apr 14, 2012
    18,277
    Canada
    Eh, just power cycle your router then, it will be simpler :) If you don't know what telnet is, then you probably didn't enable telnet on your router, so you won't be able to use it.
    Those commands would have erased the nvram settings that tells the router that someone is already logged in, and from which IP. The RT-N66U cannot allow more than one simultaneous user to be logged in, and if your IP changes before you log out, you will be locked out.
  5. Synomenon
    Jun 23, 2012
    65
    Thanks again. So those commands are not a permanent fix for this issue. I hope this is "fixed" in a future firmware update.
  6. Synomenon
    Jun 23, 2012
    65
    Is there a tutorial in setting up and using telnet with the 66U? Are these commands something that can be done using a batch file?
  7. KevTech
    KevTech Senior Member
    Feb 27, 2012
    426
    United States
  8. Nix
    Nix Occasional Visitor
    Jun 24, 2012
    32
    ... I once saw this tip somewhere... you can also enter the following at the URL instead of telnet:
    http://192.168.1.1/Main_AdmStatus_Content.asp
    Once at this page, type:
    mtd-erase -d nvram
    Push Enter key and wait for confirmation in the lower portion that nvram was erased.
    Now type:
    reboot
    Push enter
    I also noticed that a hard factory reset also does the trick sometimes.
  9. RMerlin
    Apr 14, 2012
    18,277
    Canada
    Your suggestion will erase ALL settings. A bit overkill just for a login issue, don't you think? :)
  10. Nix
    Jun 24, 2012
    32
    LOL, true...:D ... thing is when I get problems I save .cfg file, factory reset and clear nvram.... suppose it doesn't help if you save problem into the .cfg file. Whilst on the topic, isn't it possible to type your code into that URL-based page as well: "http://192.168.1.1/Main_AdmStatus_Content.asp"?
  11. RMerlin
    Apr 14, 2012
    18,277
    Canada
    Yes, except that if you can't login to the web interface, you might have a hard time accessing that page as well.
  12. DaveMishSr
    DaveMishSr Very Senior Member
    Jul 14, 2012
    539
    San Diego
    I agree with Merlin. That will wipe your NVRAM completely. It will eliminate your login issue but it will also eliminate all of your settings including those that allow you to connect with your ISP. Use the command Merlin suggested. Just make sure to set your router to enable telnet first (under the administration/system tab). Google the telnet program Putty, download it and click on the putty.exe file. Type in 192.168.1.1 (or the LAN IP address for your router if you have set a custom IP address) in the host name field and select telnet as the connection type. Once you get a DOS prompt window enter your login (admin is the default) and then your password. Then you enter the four commands Merlin has so wonderfully provided with a space between each one. That will allow you to login. Once you are used to this it should take all of a minute at most to complete. BTW, if I were you I would do whatever Merlin says and ignore everyone else.
  13. RMerlin
    Apr 14, 2012
    18,277
    Canada
    Your check is in the mail.
  14. Ancaster
    Ancaster Occasional Visitor
    Oct 16, 2012
    20
    Bump.
    I currently can't access the web interface wired or wireless, however my computer connected to the N66 LAN sees all the other LAN devices.
    Funny, the wireless devices see the SSID but won't connect.
    Should I try Merlin's first, then if that doesn't work, clear the NVRAM?
    I did save the cfg file before I started making configuration changes that lost my access.
  15. Pierino
    Pierino Very Senior Member
    Jul 13, 2012
    529
    Ohio
    I would just clear the nvram and start fresh.
  16. hjmayniac
    hjmayniac New Around Here
    Apr 18, 2013
    4
    What else can I do with the CLI in telnet - is there a complete list of the available commands somewhere?
  17. RMerlin
    Apr 14, 2012
    18,277
    Canada
    It's a whole OS there (Linux), so it's not just a small list of commands that could be documented. Listing everything that can be run and the arguments supported would fill an entire book.
  18. tomicjr
    tomicjr Occasional Visitor
    Jan 7, 2014
    11
    Orlando, FL
    Thanks for the tip in post #2!
    My AC68R has been up for 56 days, and I like to avoid unnecessary reboots.
    I also experienced this login issue when switching between http and https from the same host. May not be necessary, but I also run:
    nvram unset login_port
  19. gigi2
    gigi2 New Around Here
    Feb 2, 2015
    7
    Romania
    Is there a way to permit access coming from more than one IP without this workaround ?
Share This Page
