Hi all. Tried setting up a DMZ on the ASUS DSL-AC68U. However, it isn't working here. If I disconnect the ASUS DSL-AC68U and use the Sky UK fibre router with it's DMZ connected to my ASUS RC87U then everything works as expected. I simply want to use the DMZ on the ASUS DSL-AC68U and pass all internet traffic through to the RC87U. Have tried doing this with the firewall on and off on the ASUS DSL-AC68U and this makes no difference. My reason for wanting to use the
ASUS DSL-AC68U is that I can change the SNR for VDSL 2 and obtain a higher speed on the line.
Shall post the logs below:
ASUS DSL-AC68U
System Log - Port Forwarding
Virtual Servers
Source Proto Port range Redirect to Local Port Chain
ALL ALL 192.168.0.2
ASUS Wireless Router RT-AC87U
Virtual Servers
ALL TCP 22124 192.168.1.3 22124 VSERVER
ALL UDP 22124 192.168.1.3 22124 VSERVER
Virtual Servers
ALL ALL 192.168.0.2
Thanks for any help.
Warm regards, Phil Muir
ASUS DSL-AC68U
Virtual Servers
ALL ALL 192.168.0.2
Virtual Servers
Virtual Servers
ALL ALL 192.168.0.2
