can't get dnsmasq to work
Ojee
I'm using a Synology NAS to listen to music when I'm at work. To access it, I have DDNS running on my Asus RT-AC87U, along the lines of xxxx.asuscomm.com:1234. When I come home, my phone switches to wireless, and that's where the trouble starts. In order to keep listening, I have to log out and relogin using the internal IP of my NAS. This is a chore, and I have to do this every time I enter or leave my house. I wish this worked as seamlessly as spotify for instance.
The problem is that I can't access the external asuscomm address from inside the network. It will only access the internal IP address. I've done some digging and apparently this is a dnsmasq problem (I could be wrong), but for the life of me I don't know how to fix it. There doesn't seem to be an option on the router to force the asuscomm address to the correct IP when I'm behind my router.
What you need is called Hairpinning, NAT loopback, NAT reflection... but wait for ASUS wizards here to tell you what you need to do.
