I just got the X4s R7800 , and immediately loaded the latest Voxel firmware. I am fairly sure I mirrored all the settings exactly, including my port forward rules. The only other thing I really do is start my DHCP pool at 101 to reserve everything below for my static IPs.
I am running a Synology DiskStation DS916+ with Docker and the Abiosoft Caddy server image. I am only using it as a reverse proxy. I like how simple it is and benchmarks show it as less resource intensive as well as higher performance that nginx.
I had a issue with port 80 and 443 with my initial ASUS setup, I forget the specifics, but i believe it is was because the Synology redirects 80 to 5000 for its web console. Also perhaps the router itself uses that port for the web console. The solution was to basically do this with 80 and 443:
Router -> forwarded -> Synology -> port mapped -> abiosoft/caddy docker container
80 8080 8080:80
443 8443 8443:443
(external) (internal)
(Sorry, I am not sure how to show this in a readable table or something. Let me know how and I will edit it.)
The NAS has a static IP.
Hope this makes since, but it is probably less important.
Looking through the netgear settings, I saw some potential settings such its web console and READYshare using these ports. In my troubleshooting, I attempted to change the ports and/or disable. I don't plan to use most features like readyshare. Note the readyshare advanced page to see where I saw the ports noted there. I am pretty sure i disabled all those, including media share.
Any ideas or troubleshooting I should make sure I did?
Maybe the netgear just wont allow forwarding of 80 or 443 no matter what?
80 8080 8080:80
443 8443 8443:443
