JWadle
I have just installed an RV180 router for a new customer. The customer has Comcast Internet at 180Mbps. With default settings, the router LAN speed tests at 180Mbps down / 12Mbps up, but with a "bufferbloat" rating of "F".
In the past (with other routers), I have been able to reduce bufferbloat by setting QOS with speeds limited to 95% of maximum (e.g. 170Mbps). Typically this improved bufferbloat to B with very little loss in speed.
I tried this with the RV180, but found that the QOS settings only allow a max speed of 100Mbps. Using this max, my download speed is reduced to 60Mbps and the bufferbloat improves to C.
Why are QOS max speeds limited to 100Mbps on a gigabit router?? What do you recommend to reduce bufferbloat but still maintain speed?
