Jody
Well I am in a pickle and need some help and advice.
I currently have the following setup;
Thecus 5200XXX
http://www.smallnetbuilder.com/nas/nas-reviews/31493-new-to-the-charts-thecus-n5200xxx
Running on Cat 6 through the home with a switch and Fritzbox 7390 router.
The Nas has 5 x 2 TB green drives installed and has been great for the past few years.
I managed to get plex running on the NAS using 3rd party modules over time, however the later Plex server software is no longer supported (you need to go to OS6 which my NAS cannot run).
I have about 80% of the storage full currently with movies/tv/photos and some software/files.
I currently only really use it for file sharing and Media management to IOS/Android tablets, Samsung TV, Sony PS3/4 with Plex App and PC's. I will also be using Roku/Rasberry PI etc in the future to increase the availability of the media to dumb tv's in the house.
I am looking to upgrade to a unit that is fully supported by Plex and other media serving applications as well. I like the comfort of RAID 5 and that has helped when i had a disc play up a few months back and was easily replaced.
I am not an experienced network person or IT Guru. to be honest getting the Thecus going was a steep learning curve..
I want to modernise my Nas have something that is well supported and increase my storage space. I would like to stick with 5 bay due to the $$ and would look at bigger drives in the new NAS however I may be thinking this all wrong..
I can not understand what options I have to take the data from the Thecus to a new NAS easily and the most cost effective?
Can you guys give me some help on possible solutions to my needs?
Kind Regards
Jody
Thecus 5200XXX
Kind Regards
Jody
