Dismiss Notice
Welcome To SNBForums
Configure the port used for SIP helper
Discussion in 'Asuswrt-Merlin' started by Mistermoonlight, Feb 26, 2013.
  1. Mistermoonlight
    Mistermoonlight Regular Contributor
    Feb 16, 2013
    Running latest Merlin build for rt-n66u. I am running a voip device on the lan. I have fowarded the ports from outside for rtp and sip to the voip device. When i am doing an outgoing call, there is an rtp stream that can go from wan to lan correctly (here the voice), but the rtp stream from lan to wan gives a lot of problem (usually is simply not there at all and we hear silence.
    I have tried using the disable net helper function, but enable/disable changes nothing. I guess that i need the sip helper working to solve my problem, but the SIP port used by my device is not the standart sip port 5060.
    How can i reconfigure the sip helper to use a different sip port than the default 5060?
    Any other idea?
  2. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    Untested, by try this:
    1) Disable the SIP helper
    2) Create an init-start script, with the following (change the port as appropriate):
    modprobe ip_conntrack_sip ports=5060
    3) Reboot
    Check the Wiki on Github for details on how to use User Scripts.
  3. Mistermoonlight
    Feb 16, 2013
    Thanks for the idea.
    It seems to be more something like this that i tried to use for the init-start script (sip port is 5085 for me):
    rmmod nf_nat_sip.ko
    rmmod nf_conntrack_sip.ko
    modprobe nf_conntrack_sip ports=5085
    modprobe nf_nat_sip
    but i discovered later than the problem was not related to the router so i didn't test any further.
    Thanks anyway
Share This Page
