D
Deleted member 27741
Guest
I want to be able to connect my N66U to an outside vpn for my use at home, while at the same time an outside user connects to the openvpn server(s) on my N66U itself.
Edit-
Well, that was easy- this firmware's flexibility never ceases to amaze. I set up policy based routing on the client and set the computers I wanted to route through the tunnel. What an easy solution. The computers that are not set to route through the client tunnel are able to connect to and use the N66U openvpn server normally. Brilliant, just brilliant.
Edit-
