Steven2500
Hi all,
I have the following problem and do not know what the correct setup - Connection type I need to set up,
I have a Holiday home on a site, it comes with a free Wireless Network Password, that supposedly allows 1 device to connect to it, (It will lock the password with the MAC address, So I don't want to try it out) I want to connect multiple devices to the free network.
I figured I could use an old router as a go between, I have a DG834G lying around.
I want to connect this to the site network then connect loads of devices to the router.
I do not have access to the Holiday sites wireless network. Other then connecting to it the normal wireless way.
Can this be done?
Thanks in advance!
Can this be done?
Thanks in advance!
