I have task to cover 8000 sqm complex on the sea. Complex has pool and about 12 houses. In every house there are 3 floors and I need good WiFi. There is LAN cable to every apartment in the house. I can tell you that max sqm of the floors are 120m2. There is no IPTV, but the speed of internet is 20-30mbps. I'm considering couple of variants
1st http://rts-bg.com/en/wireless-management-solution/615-neutron-series-wlan-starter-kit.html
Advice by the reseller was to put 2 in every house - on the 1st and 3rd floor respectively. Walls are brick, so to put dual-band like EAP 600 is useless I think.
2nd is again with indoor but with Mikrotik RB951G or RB2011 - I think 2 per house will cover everything also.
optionally I will need to reboot them with PoE switch putten in the underground floor, but for now they are expensive.
3rd is with outdoor antennas - again maybe sector antennas but problem is where to put them to get the signal and how many I will need. Also can you recommend me software for designing - using AutoCAD scheme. This is the AP to put.
http://rts-bg.com/en/outdoor-access-point/225-enh202-wireless-outdoor-ap.html
