[SOLVED] Cronjob parse error
octopus
Part of the Furniture
I get parse error when execute script with cronjob but not with ssh.
Apr 28 18:44:01 crond[863]: user octopus: parse error at down
Apr 28 18:44:01 crond[863]: user octopus: parse error at *19
Get error with cronjob
cru a myfile down "0 *18 * * * /jffs/myfile.sh down"
But not with ssh
I use myfile.sh down/up
what have i missed in this config?
Octopus
I see no space between "*" and "18". That's not a valid parameter.
I have set space between * and 18 and crone is execute.
But i still have parse error.
i use myfile.sh down to execute my .sh file
Apr 29 11:00:01 crond[863]: user octopus: parse error at down
case "$1" in
  down)
       content 1
  down-1)
       content 2
    up)
       content 3
    up-1)
       content 4
Check that it somehow didn't get changed to DOS/Windows format with carriage returns.
dos2unix myfile.sh
dos2unix myfile.sh
I always make my script with Notepad++ with EOL-conversion to Unix.
I know it's only a code snip....but did you close your 'case' selection with an 'esac'?
Yes i have this in end of script.
 echo "usage: $0 {down : down-slow | up : up-slow}"
  exit 0
esac
Got it!
The syntax of your "cru" command is wrong and putting rubbish in the crontab
# cru a myfile down "0 *18 * * * /tmp/zzz.sh down"
# cru l
30 6 * * * /sbin/service restart_wireless #RestartWireless#
00 6 * * * /jffs/scripts/adblock.sh /tmp/mnt/VERBATIM/ASUS #AdBlock#
down 0 *18 * * * /tmp/zzz.sh down #myfile#
# tail /tmp/syslog.log
Apr 30 01:46:01 crond[382]: user admin: parse error at down
Apr 30 01:46:01 crond[382]: user admin: parse error at *18
Try this:
cru l
then use "cru d myfile" to delete the incorrect entry, then
cru a myfile-down "0 18 * * * /jffs/myfile.sh down"
Got it!
# cru l
Try this:
cru l
TANK YOU!!!
Thats working just fine, no more parse error. Can use up and down now.
Must use Hyphen (between myfile and down.)
Apr 30 13:46:01 crond[863]: crond: USER octopus pid 8656 cmd /jffs/configs/wanblock.sh down
Apr 30 13:50:01 crond[863]: crond: USER octopus pid 8720 cmd /jffs/configs/wanblock.sh up
Octopus
