Custom domains with dnsmasq on RT-AX92U
rasto
I switched from RT-AC68U to pair of RT-AX92U, but i didn't expected that Merlin doesn't support RT-AX92U yet :-(
Everything is working perfect, but it's not possible set "Custom domains with dnsmasq".
On RT-AC68U i set it according to https://github.com/RMerl/asuswrt-merlin.ng/wiki/Custom-domains-with-dnsmasq.
I created file dnsmasq.conf.add on router and I can change/add settings with WRT Settings (https://www.medo64.com/wrtsettings/), but i have no idea which variables need set.
Can somebody help me?
I created file dnsmasq.conf.add on router...
That is a Merlin-only config file. Stock firmware doesn't support it. You'll need to find another way of modifying the dnsmasq configuration. I'm not sure whether that's even possible: link.
... and I can change/add settings with WRT Settings (https://www.medo64.com/wrtsettings/), but i have no idea which variables need set.
Using that utility to change NVRAM settings is potentially risky but also pointless as you can use the router's nvram command.
thanks for information, i will try communicate also directly with Asus if they can add this feature to original firmware or if exist some other possibility to solve it
