Dec 31 Log Entries between current dates??
rirusssma
I just noticed that I'm getting General log entries dated Dec 31 everyday between the current days. Any explanation to this?
Asus AC68U firmware 378.53.
Thank you.-
  • LOG partial 1.txt
Thats normal, its the date before NTP updated.
No problem, you are welcome.
This NTP update seems to block communication to the router, just a while ago at 20:23 the Internet went out, I checked the Log and found the list on the attached file. When I turned the Router OFF and then ON at 20:50:43 the Internet came back. I seems that it was out during all the period with the DEC 31 XX XX times.
Does this make any sense to you guys as to why the Internet access goes out?
Any ideas? Thanks
  • LOG partial 2.txt
