Download this run it and post its log.
http://www.virustotal.com/file-scan...22f28538d9538b6578933ade7ebe348743-1311650621
File looks a little dodgy. False positives are possible, especially when dealing with anti-malware products. Either way, agree with GregN. Software does not address OP's issue.
DON'T
I recommend against running any unsolicited .exe
What is this executable going to do to recognize a man in the middle attack?
Why Now? This is an older thread.
All seems rather dodgey, when there is a doubt, there is no doubt....
http://screen317.spywareinfoforum.org/notes.htmlResults of screen317's Security Check version 0.98.9
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 8.5
Anti-malware/Other Utilities Check:
Malwarebytes' Anti-Malware
HijackThis 2.0.2
Java Web Start
Java 2 Runtime Environment, SE v1.4.2_03
Java 2 Runtime Environment, SE v1.4.1_02
Adobe Flash Player 10
Adobe Reader 7.0.9
Out of date Adobe Reader installed!
Process Check:
objlist.exe by Laurent
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
AVG avgemc.exe
DNS Vulnerability Check:
GREAT! (Not vulnerable to DNS cache poisoning)
`````````End of Log```````````
On the day you join, you post a one-line message.
In a thread that last saw a post three months ago.
The message links directly to an executable, not a web site.
You tell folks to blindly run this unknown executable.
You provide no context, or any explanation on how this download solves the topic of the thread.
If that isn't the very definition of dodgy, then what is?
I apologize for the LATE reply. Im typing with one hand at the moment because I injured my right arm and couldnt be active everywhere like I use to be. I did say run it and post the log.
Next time just use a link checker simple. Sandboxie and BSA is another good analyzer. But you gave bad feedback on a application which you have never used or have no knowledge about. Which is not the right way to go. Either test it or do some research on it. Theres a very good reason I tell people to run that app
ADOBE and JAVA
You seem to misunderstand, my feedback had nothing to do with the application. It was your sparse post that I took issue with.
What you mean sparse? Asking someone to post a log to show them where theyre security holes are?
Sparse: not rich, lacking detail, short.
You did not explain why someone should execute the link, or how it helped defend against a Man in the Middle attack.
Your post lacked critical information that would lend it credibility, instead it looked dodgy, suspect.
The original poster, the person you were asking, went away more than three months ago.
| Thread starter | Title | Forum | Replies | Date |
| A | Seeking advice. APT / MitM | General Network Security | 4 |
Welcome To SNBForums
