Development suggestion of user-defined Qos
ac66ub1
Look at this user-defined Qos rule setting, there's no way to move item up and down.Which means if you want to change the order, you need to delete items and add them again.
You'll need to speak directly to ASUS devs.
Changing the order of the list does not change the priority of the items or the order the rules are processed. Just the way you look at them.
Sent from my P01M using Tapatalk
No!
Checked with Asus service,The upper rule of the table is adopted first.Which means the order influence the priority.
No!
thats even true to all rules that they have to be processed one after the other in a serial way.
There are not unlimited priorities to make it seamless.
No!
If you knew the answer why did you ask the question? Adaptive QOS seems to work better for me... why don't you try it?
No!
If you talk to them again, tell them I also want to be able to sort the assigned IP table by at least the assigned IP address. :)
OE
H Suggestion: Reboot on schedule (task) and VPN autoconnect ASUSWRT - Official 7
