cookiecookie2019
I have two RT-AX92U routers. Both have firmware 3.0.0.4.386_41712.
I connected a USB drive to the primary router and set up Samba share. All devices that connect to the WIFI of the primary router can see the USB drive and the files on it. But devices that connect to the AiMesh Node do not see the USB drive. The Network panel of Mac Finder shows nothing. And tried to use the 'Go to the folder' in Finder with path 'smb://DRIVER_NAME/FOLDER_NAME' doesn't work either.
Any idea what settings I need to config?
Thank you!
Thank you!
