Dhcp Issue RT-AC66U
cofetym
Using Merlin 378.55 I cannot enable or disable manual assignment, anyone else with this issue?
No issues here
Been using MAC-based DHCP assignment for over a year on my AC66U, always with the most current Merlin version
Sent using Tapatalk
I've been bad about resetting nvram after flashing! Performed a factory reset and used Johns nvram restore setting utility.
Still the DHCP assignment list will not disappear when I disable it, might have to re-flash again and input values from scratch.
Disabling it does not make the list disappear, it merely tells dnsmasq not to use the list.
Thanks everyone! Now I know that the list issue was definitely an anomaly. Updated firmware again and reset nvram. Will leave it alone till the next update.lol
