RT-AC3100 running 380.64_2
I don't use the built in DHCP server in the router, instead using Win 2012 Server R2 as the DHCP server. Everything works fine. But with wireless guest networks clients are not getting IP addresses because I have local intranet access disabled. How do I get around this?
Basically I'd like the router to only serve up IP addresses to the guest network. Is this possible?
