Does the DPI Bypass "zapret" work with Merlin firmware?
Sora
Although the DOT function was added to the merlin firmware. but
I need to bypass DPI because I live in a country where isp censors the Internet.
I've been very stressed since I started censoring at my country ISP last month.
An alternative is to install goodbyedpi( https://github.com/ValdikSS/GoodbyeDPI )
and green tunnel( https://github.com/SadeghHayeri/GreenTunnel ) on the device,
but I want to do DPI bypass at the router level.
https://github.com/bol-van/zapret/blob/master/docs/readme.eng.txt
There is a manual that can be installed on Openwrt, but I would like to install and work on the merlin firmware.
I'm a simple user so I don't know the details
I would be grateful if someone could give me the information .
If not, please tell me how to use the DPI bypass on the Merlin firmware.Thank you.
Please understand that my English is lacking.
Yes this is a really necessary feature.
If so, it would be perfect.
Simply entering these four commands allows the crucial NFQUEUE firewall rule to be activated for the two current IPv4 IPs for 'kinozal.tv'
modprobe xt_NFQUEUE
ipset create zapret hash:net
nslookup kinozal.tv;for IP in $(nslookup "kinozal.tv" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add zapret $IP;done;ipset list zapret
iptables -t mangle -I PREROUTING -p tcp --sport 80 --tcp-flags SYN,ACK SYN,ACK -m set --match-set zapret src -j NFQUEUE --queue-num 200 --queue-bypass
No idea if it does what it is supposed to do when you then attempt to access 'kinozal.tv'.
However, if DPI seemingly can't be bypassed using the 'splitting a request into segments' PREROUTING method, try the 'mangle "Host:" HTTP header' POSTROUTING method
iptables -t mangle -D PREROUTING -p tcp --sport 80 --tcp-flags SYN,ACK SYN,ACK -m set --match-set zapret src -j NFQUEUE --queue-num 200 --queue-bypass 2>/dev/null
iptables -t mangle -I POSTROUTING -p tcp --dport 80 -m connbytes --connbytes-dir=original --connbytes-mode=packets --connbytes 1:5 -m set --match-set zapret dst -j NFQUEUE --queue-num 200 --queue-bypass
So would these commands need to be entered for every site that is being blocked or is there a way to enable it for all sites?
