hi!
i have a AC3200 but am using it only to stream wireless through out the house. i attached a hard disk to the USB and have successfully installed download master to hard drive. the problem is download master doesn't start downloading unless i install a lan connection to the WAN, the problem is when i connect the AC3200 via WAN it is not anymore visible in my native network. any help appreciated...
the fix i am using right now is somewhat crude, hope somebody can help me find a more elegant solution.
router - LAN1 AC3200 -> LAN2 AC3200 -> WAN ASUS10 -> LAN1 ASUS10 -> WAN AC3200
it looks stupid but it works. any setting in download master that specifies that use a certain gateway if no internet on WAN is detected?
thanks!!!!
thanks!!!!
