DS212J and ASUS RT-N56U remote access issues
Discussion in 'Synology' started by pplatt52, Jan 12, 2012.
  1. pplatt52
    pplatt52 New Around Here
    Jan 12, 2012
    3
    Looks like there's some serious IT horsepower here - hoping someone will lend a hand to a n00b in need.
    Just set up a new DS212J (running DSM 3.2-1955) attached to an ASUS RT-N56U router (running latest firmware), and everything is going great...except remote access. I tried Synology's EZ Internet wizard, and it IDs my router, says that it sets up static IP and port forwarding for me, and that I'm good to go for web station remote access, photo station, etc. Then I test it off my LAN, either through the external IP address/port or DDNS I set up on no-ip, and I get a 504 timeout error every time. Likewise, testing connections in Synology's Router Setup leads to "Failed" messages.
    Googled a bit, read up on things, and tried to set up static IP myself (followed Windows 7 directions on portforward.com) and also port forwarding manually in ASUS's WAN settings, and I get the same result...I think I did those things right, but I'm not 100% sure...none of the portforward.com walkthroughs look exactly like my ASUS' settings page, and I feel like I've only set up static IP on my laptop, not on the router or NAS itself...when I tried to do turn DHCP off in the ASUS WAN settings, it told me the subnet mask I got from ipconfig (255.255.255.0) was invalid. Huh? Isn't that like the default subnet mask? Do I need to adjust settings for both the router and the NAS to be static IP, or just one? What am I missing??
    Help!
  2. Log in / Register to remove this ad
  3. stevech
    stevech Part of the Furniture
    Mar 13, 2010
    6,670
    San Diego
    Too much, too little! It is confusing. We'll have to talk you through it -best done by phone.
    The NAS tried to use Universal Plug and Play (UPnP) to config your router. That's if'y.
    What you want, on the router, independent of the NAS' attempts to do it automatically:
    WAN side settings in your router: whatever your ISP requires.
    LAN side:
    LAN IP addresses: Probably now something like 192.168.1.1 for your router, subnet mask 255.255.255.0. Thus, the NAS and all computers are 192.168.1.x, where x is 1 to 254.
    DHCP server enabled
    DHCP server config: LAN address range start/end, typically 192.168.1.100 to 200.
    On the NAS: connect to it and give it a static mode IP of 192.168.1.250 or some such - and address not in the DHCP server range.
    On the router again
    Config port forwarding per Synology's instructions. Each port number will forward to the same port number, and to the IP addr. of the NAS, say, .250.
    That should do it. FTP (passive) on the NAS should work- FTP port number would have been among those you config. And if you set the NAS for PASSIVE MODE FTP, you don't need additional port numbers opened.
    How do you like the DS212j? A little lower speed CPU than the DS212, but less costly.
  4. stevech
    Mar 13, 2010
    6,670
    San Diego
    LAN side:
    DHCP server enabled
    On the router again
    You'll need no-ip or dyndns setup on the router- login and password for that service. Your domain name and IP will take hours/days to propagate around the Internet to the DNS servers. You can check if it's on the DNS server your router using by doing a windows command line: nslookup mydoman.net or whatever it is. If it's not found, you can use the numeric WAN address given to your router by your ISP while waiting for DNS to propagate.
    If you override your ISP's DNS choices given to the router, and setup your own preferred DNS servers, I suggest entering 4.2.2.2 and 8.8.8.8 for DNS.
  5. pplatt52
    Jan 12, 2012
    3
    You're a gentleman and a scholar, sir - that did it.
    For some reason, DSM wouldn't let me pick a port outside the router's range (2-254), so I went into the router and adjusted the range to max out at 150, then set the IP for the NAS at 200, manually forwarded ports in the router settings, and it's up and running. Thanks again.
  6. pplatt52
    Jan 12, 2012
    3
    It's my first NAS, so I'm not the best judge, but so far, so good. Apart from the remote connect issue, set up has been fairly intuitive, and speeds seem to be good.
  7. klauzer
    klauzer New Around Here
    Nov 21, 2012
    1
    I am having big problems with this NAS. I can't even connect to the "package center" in NAS?
    Where did you made this changes IP for NAS at 200?
Share This Page
