Dismiss Notice
Welcome To SNBForums
Dual Band Router Question
Discussion in 'General Wireless Discussion' started by SigEpStyles, Feb 28, 2011.
  1. SigEpStyles
    SigEpStyles New Around Here
    Feb 28, 2011
    Hi all -
    New to the forum and have a couple of questions if someone has some time to help.
    I just purchased a new wireless router (Belkin N600) and it has dual bands 2.4 & 5.
    It has the option to name each band's SSID differently. I currently have them set to the same name.
    Here are my questions:
    1. If the components in my house are set to pick up and log into the SSID by default, will they automatically connect to whichever on is faster or less busy, or will they just log into one?
    2. Should I be naming the SSID's differently and specifying which components connect to each one?
    Does it make a difference?
    For reference, here's what's accessing the router:
    2 TiVo's
    1 Logitech Revue
    1 PS3
    2 laptops
    Thoughts? Am I overthinking this? If everything is working fine now, should I just leave it, or can I improve performance somehow?
  2. thiggins
    thiggins Mr. Easy Staff Member
    May 18, 2008
    In general, wireless devices aren't very smart about what they connect to. If your clients are dual-band capable, they will connect in the priority order set by their wireless connection manager if the manager has this capability.
    If not, they'll connect in some unknown manner and continue to use that connection unless it is not there.
    If you want to control the band that your devices connect to, and you will if you are trying to do media streaming, then give the SSID's different names and set the connection for each device as you desire.
Share This Page
