AC86U running latest Merlin, and I followed the instructions to install Skynet on it. I have a 32Gig USB key, but I used the UI to format so it's formatted as FAT.
After reading & learning more, I want to install Entware. It requires that the USB key be ext formatted, and I know now I can do that via ssh.
Is it as easy as using the UI to backup my jffs to a local .tar file, use 'fd' to reformat to ext4, the Restore from the UI to plop the contents back on, and presto? I'm thinking maybe shutting down Skynet before doing this in case there are locked files. Anything else I should know?
