[Solved] Enable LAN login from SSH | samba issue
itarill
Hey guys,
I have two issues with my router, and I'd really really appreciate any help I get:
1. Somehow I blocked LAN access of my router. Now to add to my ignorance, I have not yet backed up the configs because I was not finished with it (but I definitely do not want to start over). I can SSH to the router, but I do not know either the OS or the CLI commands to solve the issues (I could make do with a cisco router, but this I cannot...)
2. I have trouble configuring samba share between the AC56U and the linux mint on my PC. Whenever I configure the share to allow guest login, this works:
[/etc/fstab]
//AC56U/sharename/ /mnt/smb/myfolder cifs credentials=/home/myusername/.smbcredentials,iocharset=utf8,sec=ntlm 0 0
the contents of the cred file are:
[~/.smbcredentials]
username=AddedUserToSambaUsersOnRouter
password=doubleTripleCheckedPasswordAndTheyDoMatch
Whenever I switch off guest login and try mount -a I get an error message saying the share does not exist.
Thanks.
P.S.: thanks for all the Good work, Merlin!
That's because when you turn off guest access the path changes (it's just the way Asus does it :rolleyes:)
Guest login On:
\\Rt-ac68u\verbatim\ASUS
Guest login Off:
\\Rt-ac68u\asus
If you configured it to only accept logins from specific IP, disable it with these commands:
nvram set http_client=0
nvram commit
service restart_httpd
Guest login On:
Guest login Off:
\\Rt-ac68u\asus
Thanks. I was able to mount it w/ "Simpler share naming" turned on (I could not manage with the setting turned off, though).
