ongbenghui
I keep getting these errors on the system log. Is this something that I should be alarm about ?
Apr 22 20:18:14 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Apr 22 20:18:14 kernel: sd 2:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 22 20:18:14 kernel: sd 2:0:0:0: [sda] Sense Key : Illegal Request [current]
Apr 22 20:18:14 kernel: sd 2:0:0:0: [sda] Add. Sense: Invalid command operation code
Apr 22 20:18:14 kernel: sd 2:0:0:0: [sda] CDB: Write same(16): 93 08 00 00 00 00 28 e9 cc 68 00 00 00 60 00 00
Apr 22 20:18:14 kernel: end_request: I/O error, dev sda, sector 686410856
Apr 22 20:18:15 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Apr 22 20:18:15 kernel: sd 2:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 22 20:18:15 kernel: sd 2:0:0:0: [sda] Sense Key : Illegal Request [current]
Apr 22 20:18:15 kernel: sd 2:0:0:0: [sda] Add. Sense: Invalid command operation code
Apr 22 20:18:15 kernel: sd 2:0:0:0: [sda] CDB: Write same(16): 93 08 00 00 00 00 28 e9 cd 58 00 00 00 70 00 00
Apr 22 20:18:15 kernel: end_request: I/O error, dev sda, sector 686411096
