filesystem script skipping checks
Swistheater
Mon Feb 13 19:00:37 EST 2017 Unknown filesystem type on /dev/sda1 - skipping check.
Mon Feb 13 19:00:45 EST 2017 Unknown filesystem type on /dev/sdb1 - skipping check.
Mon Feb 13 19:00:44 EST 2017 Unknown filesystem type on /dev/sda1 - skipping check.
Sat Apr 21 21:01:34 DST 2018 Unknown filesystem type on /dev/sdb1 - skipping check.
Mon Feb 13 19:00:42 EST 2017 Unknown filesystem type on /dev/sdb1 - skipping check.
Mon Feb 13 19:00:48 EST 2017 Unknown filesystem type on /dev/sda1 - skipping check.
It's a known limitation with the script and identifying drive types. If you are using ext* drives you can replace "/jffs/scripts/disk-check" with the following contents;
#!/bin/sh
CHKCMD="e2fsck -p"
logger -t amtm "Running disk check '$CHKCMD' on $1"
printf "\n$(date) Starting '$CHKCMD $1'\n" >> /jffs/amtm-disk-check.log
e2fsck -p "$1" >> /jffs/amtm-disk-check.log 2>&1
logger -t amtm "Disk check done on $1"
so just erase every thing and place this in the scripts... would this mess up it being able to check other file system types as well I have a mix array of file system types
btw this is what is in it now
#!/bin/sh
# auto-check filesystems during boot
# generated by amtm 1.2
FSTYPE=$(fdisk -l ${1:0:8} | grep $1 | cut -c55-65)
case "$FSTYPE" in
   Linux*)
  CHKCMD="e2fsck -p";;
   Win95* | FAT*)
  CHKCMD="fatfsck -a";;
   HPFS/NTFS)
  CHKCMD="ntfsck -a";;
  logger -t amtm "Disk check: Unknown filesystem type $FSTYPE on $1 - skipping check."
  printf "\n$(date) Unknown filesystem type $FSTYPE on $1 - skipping check.\n" >> /jffs/amtm-disk-check.log
  exit 1;;
esac
$CHKCMD $1 >> /jffs/amtm-disk-check.log 2>&1
okay so I replaced it with that. I think I will just set the others to run on a scheduled check since they are the nonessential
Can't ever say I've purposely ran the wrong command on a different file-system, I wouldn't recommend it though. I used the edited version because I know all my drives are ext4 and never anything else.
There's nothing to schedule in the amtm disk checker for the reason that you can't do a check on a mounted drive or partition. Hence, the check only runs at boot before the device is being mounted.
#!/bin/sh
CHKCMD="e2fsck -p"
@Adamm will your truncated version of the check script work on ext2 or just ext4?
