Firmware Upgrade Unsuccessful Message
tx2nc
I am currently on firmware 3.0.0.4.374.39_0 and am trying to upgrade to RT-N66U_3.0.0.4_374.40_0.
I've downloaded from the webpage, extracted the files, but when I browse to the firmware file and try to "upload" I get the following error message:
Firmware upgrade unsuccessful. It may result from an incorrect image or transmission error.
Router; ASUS RT-N66W
Firmware file for upload: RT-N66U_3.0.0.4_374.40_0.trx
Computer connected to modem via ethernet.
Any suggestions? Thanks for the help!
Try from another web browser and be sure you are not under restore settings tab
Reboot your router without any USB disk plugged in, to ensure you have enough free memory for the firmware upgrade to proceed.
I did try the other browsers... Firefox, Chrome, IE... no change, same error.
However, rebooting after removing the USB drive did the trick. No issues with the upgrade or errors.
Thanks for the quick responses!
