Fix for Erratic Windows 7 Ping
john9527
Part of the Furniture
I was setting up a new PC, and ran into problems with the wireless with very erratic ping times and slow transfer rates. After banging my head against the wall for a while, I realized I forgot to apply the change to force Windows to use a single system clock. Posted as a reminder...data and fix below.....
Before Fix
(C:\)
ping -n 10 ACER-E3FC0000
Pinging ACER-E3FC0000.lan [192.168.1.123] with 32 bytes of data:
Reply from 192.168.1.123: bytes=32 time=383ms TTL=64
Reply from 192.168.1.123: bytes=32 time=78ms TTL=64
Reply from 192.168.1.123: bytes=32 time=1ms TTL=64
Reply from 192.168.1.123: bytes=32 time=203ms TTL=64
Reply from 192.168.1.123: bytes=32 time=421ms TTL=64
Reply from 192.168.1.123: bytes=32 time=109ms TTL=64
Reply from 192.168.1.123: bytes=32 time=202ms TTL=64
Ping statistics for 192.168.1.123:
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 421ms, Average = 140ms
Apply Fix
Open cmd window with Run As Administrator
Enter:
bcdedit /set {default} useplatformclock true
Reboot Windows
After Fix
(C:\)
Reply from 192.168.1.123: bytes=32 time<1ms TTL=64
Reply from 192.168.1.123: bytes=32 time=2ms TTL=64
Minimum = 0ms, Maximum = 2ms, Average = 1ms
This tweak depends on the HW/BIOS supporting HPET - so for some folks this might have a negative impact - esp on older HW that is still supported by Win7 - for Win8/8.1 and Linux/*BSD this shouldn't be needed - sometimes Win7 doesn't enable HPET on install, falling back to LAPIC/ACPI...
Check BIOS to see if there is a switch for HPET, if so, make sure it's enabled, and Windows will use it (so will linux).
I think you need to go back quite a bit for a problem (the change makes a big difference for me down to a lowly Intel N450 Netbook).
Also, my experience (at least with Win 7) is that it's hit or miss being picked up. I had to set it manually on an ASUS 99FX board with HPET enabled.
If it does make things worse for you....it's easily disabled. From a Run as Administrator cmd window...
bcdedit /deletevalue {default} useplatformclock
and reboot.
