sfx2000
Part of the Furniture
Doing a project - stumbled on these over at the local Costco - and Amazon has the drives at the same price...
USB3 drive with UAS - very fast - 4TB and bus powered - $125 at your local Costco, and same price at the Amazon -- Seagate 4TB Backup Plus portable USB3 drive - nice review/insight into that disk on Anandtech and ServeTheHome..
Amazonian linky here - http://www.amazon.com/dp/B00ZTRXFBA/?tag=snbforums-20
List on these is $240, street is $200 = out the door on the Amazon/Costco right now is $125 and change...
You can shuck the drive, put an SSD in place - it's a good USB3/SATA3 adapter...
Anyways, incredible value for a very high density 2.5 inch drive - it's too thick to stuff into most laptops (15mm), but being bus powered - and low power enough, good for many here...
sfx
sudo hdparm -Tt /dev/sdb
/dev/sdb:
Timing cached reads: 2628 MB in 2.00 seconds = 1314.10 MB/sec
Timing buffered disk reads: 346 MB in 3.02 seconds = 114.76 MB/sec
dmesg output on the hotplug
[ 1544.449519] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 1544.467701] usb 2-1: New USB device found, idVendor=0bc2, idProduct=ab28
[ 1544.467709] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1544.467713] usb 2-1: Product: BUP BK
[ 1544.467717] usb 2-1: Manufacturer: Seagate
[ 1544.467721] usb 2-1: SerialNumber: <BLIP>
[ 1544.488397] usbcore: registered new interface driver usb-storage
[ 1544.497781] scsi host2: uas
[ 1544.498501] usbcore: registered new interface driver uas
[ 1544.499281] scsi 2:0:0:0: Direct-Access Seagate BUP BK 0304 PQ: 0 ANSI: 6
[ 1544.499911] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1544.500220] sd 2:0:0:0: [sdb] Spinning up disk...
[ 1545.502947] .......ready
[ 1551.537167] sd 2:0:0:0: [sdb] 7814037167 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 1551.537177] sd 2:0:0:0: [sdb] 2048-byte physical blocks
[ 1551.567993] sd 2:0:0:0: [sdb] Write Protect is off
[ 1551.568001] sd 2:0:0:0: [sdb] Mode Sense: 4f 00 00 00
[ 1551.568170] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1551.727310] sdb: sdb1
[ 1551.728476] sd 2:0:0:0: [sdb] Attached SCSI disk
Info on the drive - this is probably more interesting to the NAS folks...
sfx
/dev/sdb:
$ sudo hdparm -I /dev/sdb
/dev/sdb:
ATA device, with non-removable media
Model Number: ST4000LM016-1N2170
Serial Number: <BLIIP>
Firmware Revision: 0003
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Used: unknown (minor revision code 0x001f)
Supported: 9 8 7 6 5
Likely used: 9
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 7814037168
Logical Sector size: 512 bytes
Physical Sector size: 4096 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 3815447 MBytes
device size with M = 1000*1000: 4000787 MBytes (4000 GB)
cache/buffer size = unknown
Form Factor: 2.5 inch
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 128
Recommended acoustic management value: 208, current value: 0
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* Write-Read-Verify feature set
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Gen3 signaling speed (6.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Write Same (AC2)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
unknown 206[12] (vendor specific)
unknown 206[13] (vendor specific)
* DOWNLOAD MICROCODE DMA command
* WRITE BUFFER DMA command
* READ BUFFER DMA command
Security:
Master password revision code = <BLIP>
supported
not enabled
not locked
not frozen
not expired: security count
supported: enhanced erase
Logical Unit WWN Device Identifier: <BLIP>
NAA : 5
IEEE OUI : 000c50
Unique ID : 0902e08cc
Checksum: correct
