Hello
Thanks for reading my post, I think this is a general router question rather than anything specifically to do with ZeroShell VM router that I have set up.
I am a Newbie at setting up a ZeroShell router, think I done rather well so far, but I can’t figure out how to configure the final step
My setup
Exsi system with three network cards (run two networks one virtual and one physical)
Network Card 1 ETH00 DHCP internet router (management port) 192. 168.0.1 as its DFG
Network Card 2 ETH01 192.168.90.1 255.255.255.0
Network Card 3 ETH02 192.168.60.1 255.255.255.0
I am trying to set up a new test environment for Xendesktop with one network hosting the enterprise part of the network and the seconded hosting the VMS on a XenServer.
The network cards will act as the network Default gateway (DFG) both networks should have access to the internet and should be able to communicate with one another (same domain)
Configuration
Configured the network interfaces on my router with the above information
ETH00 has NAT enabled
Created a DNS FWD to 192. 168.0.1 my internet router DFG
Turned off Windows Firewall on everything
The issue
Both networks have internet access but are unable to communicate with one another
Host1 192.168.90.11 – Internet access works
Ping 192.168.90.1 – its own DFG
Ping 192.168.60.1 – other DFG
Ping 192.168.90.12 – Failed to Ping host on another side
Same if I try from the other side of the network, I am guessing I have overlooked something simple
Thanks for your help
My setup
Configuration
The issue
