help...coming from ddwrt and can't get openvpn working...
Pupster
I copied and pasted my relevant certificates/keys into ASUS Merlin on my RT-AC5300. Here are my settings: (I would like to use TAP and bridged mode for my own reasons).
Advanced Settings
Interface Type
TAP
Protocol UDP
Server Port (Default : 1194) 1194
Firewall Auto
Authorization Mode TLS
Username/Password Authentication No
Extra HMAC authorization (TLS-Auth) Disable
Auth digest Default
Allocate from DHCP No
Client Address Pool 192.168.2.125 192.168.2.149
Poll Interval minute(s) (Disable : 0)
Direct clients to redirect Internet traffic No
Respond to DNS No
Encryption cipher AES-256-CBC
Compression Adaptive
TLS Renegotiation Time seconds (Default : -1) -1
Global Log verbosity (Between 0 and 11. Default: 3) 3
Manage Client-Specific Options No
Under custom config, I have the following (which I wonder if it overwrites some of the above??):
# Tunnel options
mode server # Set OpenVPN major mode
proto udp # Setup the protocol (server)
port 1194 # TCP/UDP port number
dev tap0 # TUN/TAP virtual network device
keepalive 15 60 # Simplify the expression of --ping
daemon # Become a daemon after all initialization
verb 3 # Set output verbosity to n
comp-lzo # Use fast LZO compression
# OpenVPN server mode options
client-to-client # tells OpenVPN to internally route client-to-client traffic
duplicate-cn # Allow multiple clients with the same common name
# TLS Mode Options
tls-server # Enable TLS and assume server role during TLS handshake
For my connection config file:
client
dev tap
;dev tun
;dev-node MyTap
;proto tcp
proto udp
remote secret.com 1194
route-delay 5
;remote my-server-2 1194
resolv-retry 60
nobind
;user nobody
;group nobody
;auth-user-pass
persist-key
persist-tun
;http-proxy-retry # retry on connection failures
;http-proxy [proxy server] [proxy port #]
;mute-replay-warnings
ca ca.crt
cert client1.crt
key client1.key
ns-cert-type server
comp-lzo
verb 3
client
dev tap
;dev tun
;dev-node MyTap
;proto tcp
proto udp
remote pupster.asuscomm.com 1194
route-delay 5
resolv-retry 60
nobind
;user nobody
;group nobody
;auth-user-pass
persist-key
persist-tun
ca ca.crt
cert client1.crt
key client1.key
ns-cert-type server
comp-lzo
verb 3
And here's the logfile error from OpenVPN Gui under Windows 10:
Wed Jun 01 01:19:15 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:19:15 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:19:15 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:19:15 2016 MANAGEMENT: >STATE:1464758355,RECONNECTING,tls-error,,
Wed Jun 01 01:19:15 2016 Restart pause, 2 second(s)
Wed Jun 01 01:19:17 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:19:17 2016 MANAGEMENT: >STATE:1464758357,RESOLVE,,,
Wed Jun 01 01:19:17 2016 UDPv4 link local: [undef]
Wed Jun 01 01:19:17 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:19:17 2016 MANAGEMENT: >STATE:1464758357,WAIT,,,
Wed Jun 01 01:20:17 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:20:17 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:20:17 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:20:17 2016 MANAGEMENT: >STATE:1464758417,RECONNECTING,tls-error,,
Wed Jun 01 01:20:17 2016 Restart pause, 2 second(s)
Wed Jun 01 01:20:19 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:20:19 2016 MANAGEMENT: >STATE:1464758419,RESOLVE,,,
Wed Jun 01 01:20:20 2016 UDPv4 link local: [undef]
Wed Jun 01 01:20:20 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:20:20 2016 MANAGEMENT: >STATE:1464758420,WAIT,,,
Wed Jun 01 01:21:20 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:21:20 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:21:20 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:21:20 2016 MANAGEMENT: >STATE:1464758480,RECONNECTING,tls-error,,
Wed Jun 01 01:21:20 2016 Restart pause, 2 second(s)
Wed Jun 01 01:21:22 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:21:22 2016 MANAGEMENT: >STATE:1464758482,RESOLVE,,,
Wed Jun 01 01:21:22 2016 UDPv4 link local: [undef]
Wed Jun 01 01:21:22 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:21:22 2016 MANAGEMENT: >STATE:1464758482,WAIT,,,
Wed Jun 01 01:22:22 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:22:22 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:22:22 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:22:22 2016 MANAGEMENT: >STATE:1464758542,RECONNECTING,tls-error,,
Wed Jun 01 01:22:22 2016 Restart pause, 2 second(s)
Wed Jun 01 01:22:24 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:22:24 2016 MANAGEMENT: >STATE:1464758544,RESOLVE,,,
Wed Jun 01 01:22:25 2016 UDPv4 link local: [undef]
Wed Jun 01 01:22:25 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:22:25 2016 MANAGEMENT: >STATE:1464758545,WAIT,,,
Wed Jun 01 01:23:25 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:23:25 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:23:25 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:23:25 2016 MANAGEMENT: >STATE:1464758605,RECONNECTING,tls-error,,
Wed Jun 01 01:23:25 2016 Restart pause, 2 second(s)
Wed Jun 01 01:23:27 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:23:27 2016 MANAGEMENT: >STATE:1464758607,RESOLVE,,,
Wed Jun 01 01:23:27 2016 UDPv4 link local: [undef]
Wed Jun 01 01:23:27 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:23:27 2016 MANAGEMENT: >STATE:1464758607,WAIT,,,
Wed Jun 01 01:24:27 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:24:27 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:24:27 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:24:27 2016 MANAGEMENT: >STATE:1464758667,RECONNECTING,tls-error,,
Wed Jun 01 01:24:27 2016 Restart pause, 2 second(s)
Wed Jun 01 01:24:29 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:24:29 2016 MANAGEMENT: >STATE:1464758669,RESOLVE,,,
Wed Jun 01 01:24:29 2016 UDPv4 link local: [undef]
Wed Jun 01 01:24:29 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:24:29 2016 MANAGEMENT: >STATE:1464758669,WAIT,,,
Wed Jun 01 01:25:29 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:25:29 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:25:29 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:25:29 2016 MANAGEMENT: >STATE:1464758729,RECONNECTING,tls-error,,
Wed Jun 01 01:25:29 2016 Restart pause, 2 second(s)
Wed Jun 01 01:25:31 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:25:31 2016 MANAGEMENT: >STATE:1464758731,RESOLVE,,,
Wed Jun 01 01:25:31 2016 UDPv4 link local: [undef]
Wed Jun 01 01:25:31 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:25:31 2016 MANAGEMENT: >STATE:1464758731,WAIT,,,
Wed Jun 01 01:26:31 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:26:31 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:26:31 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:26:31 2016 MANAGEMENT: >STATE:1464758791,RECONNECTING,tls-error,,
Wed Jun 01 01:26:31 2016 Restart pause, 2 second(s)
Wed Jun 01 01:26:33 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:26:33 2016 MANAGEMENT: >STATE:1464758793,RESOLVE,,,
Wed Jun 01 01:26:33 2016 UDPv4 link local: [undef]
Wed Jun 01 01:26:33 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:26:33 2016 MANAGEMENT: >STATE:1464758793,WAIT,,,
Wed Jun 01 01:27:33 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 01 01:27:33 2016 TLS Error: TLS handshake failed
Wed Jun 01 01:27:33 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 01 01:27:33 2016 MANAGEMENT: >STATE:1464758853,RECONNECTING,tls-error,,
Wed Jun 01 01:27:33 2016 Restart pause, 2 second(s)
Wed Jun 01 01:27:35 2016 Socket Buffers: R=[65536->65536] S=[64512->64512]
Wed Jun 01 01:27:35 2016 MANAGEMENT: >STATE:1464758855,RESOLVE,,,
Wed Jun 01 01:27:35 2016 UDPv4 link local: [undef]
Wed Jun 01 01:27:35 2016 UDPv4 link remote: [AF_INET]secret.ip.address.com:1194
Wed Jun 01 01:27:35 2016 MANAGEMENT: >STATE:1464758855,WAIT,,,
Any ideas why this is not working when connecting to Tomato/AsusMerlin? It connects just fine if I use DDWRT, but I prefer the Merlin interface.
Remove all the extra settings you've added, most of them will conflict with the firmware configuration, and the dev setting itself will most likely completely break your tunnel (the firmware uses a completely different interface name).
Also, use the Export button to generate your client's config file, to ensure the two are matching.
