Help me identify myAC68U-AC1900
finnpolle
Hi
I just bought a used AC68U, but I can't figure out which HW version it is.
On my old AC68U the white sticker on the back says H/W A1, but the new one just has SN, MAC adress, and PIN on the sticker. (See img) I wonder if the the new one has shielded USB 3 port and a faster GPU?
Can anyone help?
Have you tried logging into the router?
With Merlin firmware if you go to Tools ---> Sysinfo it should tell you most of what you want to know.
If the router is stock don't know what the options are.
It is stock...
log-in via ssh.
This command shows CPU and RAM clock
nvram get clkfreq
This command shows the board revision:
nvram get boardrev
Also try:
strings /dev/mtd0 | grep HW_ver
However, I don't know off-hand which HW_ver and/or boardrev maps to the various released versions.
I installed the latest Merlin FW and it turns out to be H/W A1 (sys info is identical to my old ac68u). A1 should not have shielded a USB3 to my knowledge:
RT-AC68U
Firmware Version 384.13
Firmware Build Wed Jul 31 17:27:27 UTC 2019 merlin@26eee3f
Bootloader (CFE) 1.0.2.0
Driver version wl0: May 10 2019 22:18:18 version 6.37.14.126 (r561982)
Features 2.4G 5G HTTPS PARENTAL2 WIFI_LOGO amas app appnet bcmfa bcmwifi bwdpi cfg_sync cloudcheck cloudsync dblog diskutility dnsfilter dnspriv dnssec dualwan email eula hdspindown ipv6 ipv6pt letsencrypt manual_stb media meoVoda modem movistarTriple mssid nandflash netool nfsd ntpd openvpnd optimize_xbox pptpd printer proxysta psta pwrctrl realip reboot_schedule repeater rog rrsut snmp ssh stainfo switchctrl tcode timemachine tor update usbX2 user_low_rssi usericon utf8_ssid vpnc webdav wifi_tog_btn wl6
Uptime 0 days 0 hours 5 minute(s) 40 seconds
Temperatures 2.4 GHz: 49°C - 5 GHz: 52°C - CPU: 72°C
CPU
CPU Model
ARMv7 Processor rev 0 (v7l) (Cores: 2)
CPU Frequency 800 MHz
CPU Load Average (1, 5, 15 mins) 0.16, 0.16, 0.08
Memory
Total
249.69 MB
Free 189.97 MB
Buffers 3.26 MB
Cache 13.02 MB
Swap
