High CPU utilisation following install of merlin
GeorgeW74
Running a RT-AC5300
Currently seeing 100% utilisation on one core, can ssh to device but no prompt is returned.
In addition openvpn access is very slow to unusable along with the UI not responding periodically.
Oh and of course Rescue mode isn't working.
Which version of Merlin's firmware did you install?
Which firmware were you running, including version number, beforehand?
Did you restore the router to factory default settings after flashing with Merlin and then manually configure your settings?
And when you say Rescue Mode isn't working, could you detail how you tried to access it?
Unplug any USB disk that might be present, one of the media services might get stuck while scanning the disk content.
