two questions:
a) is it possible to have two separate networks in the same house using homeplug?
b) if so, does it hurt performance?
I have my WAN antenna at the roof and no lan cable going downwards. Atm there is a router at the antena, and its LAN port is connected to one HomePlug device, so whole house is being connected to routers LAN port:
Antenna <-> Router[LAN1] <-> HomePlug <-> .... other devices
What I want to do instead is this:
Antenna <-> HomePlugNetwork1 <-> Router downstairs <-> HomePlugNetwork2 <-> .... other devices
Would this work, and does someone perhaps know how to set it up?
Thank you.
two questions:
Thank you.
