How Are You Creating An AiMesh Network?
  • I'm using two or more of the same router
    Votes: 4 26.7%
  • I'm mixing router models
    Votes: 11 73.3%
  • Total voters
    15
thiggins
Mr. Easy
Staff member
We're going to be doing an AiMesh review and are trying to figure out which routers to include. This is going to be only a two node network. Looking for input on which routers to use. We're leaning toward two RT-AC68U's since they have been around the longest.
Please take a second and hit the poll at the top. Thanks.
If Wi-fi backhaul the 5300 has the advantage of a dedicated channel for it. This is what I will be doing.
If Ethernet backhaul I think they’re all a much of a much.
I'm partial to two RT-AC86U's. I guess its too much work to test a pair of AC68U's and then a pair of AC86U's?
Might be useful to have a third option - "I am not trying to create an AIMesh Network"
That would cover those that either don't need it, or are not in a place where they could...
Tim's poll is intended to help him tailor his review toward common usage scenario, not to determine the popularity of AiMesh. Having people voting "I don't use AiMesh" isn't going to help him in his review...
@thiggins: This might be of interest (if you didn't know already about it):
https://www.amazon.com/dp/B07B316542/?tag=snbforums-20
If I was going to guess, I'd say most people didn't have 2 Asus routers when Aimesh came along. So they have one older model and one new. For me, Rt-Ac1900p and RT-AC86u
Definitely the most likely scenario.
yes, if I want mesh I would buy such hardware only for WiFi-mesh
If I got one or two (older and newer) Asus router sure I would use these for meshing instead of AP or repeater mode of the older one.
But without guest on mesh-node I will have to wait for this support to be usefull for me.
It is valid - there's a few bugs and issues/concerns about how it works, and that option is useful and relevant whether to review or even fix things there..
What Merlin said.....
I just bought and installed two refurb ac66ub1's with latest 21045 factory ac68u firmware.
House is 43x32x20, main router on top floor, 2nd router is in 36x24 attached garage wired to WAN port on gigabit near ceiling.
I disabled NAT acceleration because my internet speed is 150mbit and roaming assistant is -55 rssi for 2.4ghz, -70 for 5ghz.
Plot is .4 acre, coverage is great everywhere although I could probably add a 3rd wired unit to the basement, only been 2 days but it's working without issue so far... I have many wifi home automation products, phones, laptops and android tv boxes.
I'm an IT guy for the past 20yrs and have always used aftermarket firmware on everything but I dont yet feel the need to change anything here.
