How do I get rid of channels 1 + 5 STOCK V1.0.5.64_1.1.88
pege63
How do I get rid of channels 1 + 5, I just want the channel 1?
Enable coexistence at 20/40 MHz is NO / OFF
The FW is STOCK V1.0.5.64_1.1.88
And does Smart Connect working in this FW?
Check (turn it on) Enable coexistence at 20/40 MHz (good neighbour policy - you are probably causing interference on yours, and your neighbours wifi), and, in my opinion, I would move over to channel 11.
After som reboots on the Router it working again and channel 11 is crowded BUT still does Smart Connect working?
Smart Connect is supported and working with this FW version.
For 2.4G to use channel 1 and not 1+5, you'll need to change the 2.4G wireless mode from 600 Mbps to 289 Mbps. This will make 2.4G run in HT20 mode instead of HT40 mode. Otherwise, it will drop to HT20 only when there’s other 2.4G AP's using adjacent channels.
Yes i notice that when i walking around my apartment it switches between the R7000 and R7800 on my Sony Aqua M4 mobilephone.
A Voxel RBS50 mesh with Stock RBR50v2 NETGEAR AC Wireless (Wi-Fi 5) 4
