How do I solve this conundrum?
I created two VLANs, one wired, and the other wireless (on a DMZ) and thought I was pretty well off by keeping my wireless devices isolated from the wired network.
My wifi VLAN is running on an older mac Airport extreme base station with just three ethernet ports, one of them used to connect to another airport express to create a wifi "roaming network".
Now, I have two media receivers which require ethernet to play 24 bit /192khz audio files stored on a media server. The problem is that I now want to use an ipod/iphone/ipad as a DLNA access control point for the media receiver using wifi.
The only way I can see around this is to move my UPnP server and the media receivers over to the wireless VLAN by hooking them up to the router using ethernet. I am not thrilled about doing this. I am out of ports on the Airport extreme meaning I need a new router or switch. I will also have to figure out a new backup solution every time I add music or video as I had my current backup is set-up through the LAN. More importantly, I really want to keep the two VLANs isolated for security.
Is there a better solution to than shifting the media server and media receivers to the wireless side of the network?
