If I have two bands on my router and I connect a wireless g to a 2.4 and a wireless n to a 5 band shouldn't each band operate at optimal wireless speed? But if I connect a wireless g to a 5g and a wireless n to a 5g then the 5g band will throttle down to the lowest speed of the wireless g - is this correct?
My question is spearheading the various bits of information out there that says if you connect different generation wireless devices to a band then that band will throttle down it's max speed to the lowest common denominator.
If anyone can provide a good link or explanation to this I'd appreciate it.
Cranso
Cranso
