How to check LAN Speed / connection
Cloedu
Hi Forum
How can i check the LAN connections, if the speed is 100 oder 1000 bit/s? I couldnt find any page showing this information.
=> using stock or Merlins Firmware
Claude
Getting LAN-Speed status
Hi Claude,
Try this command on the telnet interface: robocfg show
You should get a output like similare link this one:
Switch: enabled gigabit
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: on mac: xx:yy:zz:aa:bb:cc
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: on mac: xx:yy:zz:aa:bb:cc
Port 2: DOWN enabled stp: none vlan: 1 jumbo: on mac: xx:yy:zz:aa:bb:cc
Port 3: 100FD enabled stp: none vlan: 1 jumbo: on mac: xx:yy:zz:aa:bb:cc
Port 4: 1000FD enabled stp: none vlan: 1 jumbo: on mac: xx:yy:zz:aa:bb:cc
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: xx:yy:zz:aa:bb:cc
VLANs: BCM53115 enabled mac_check mac_hash
1: vlan1: 1 2 3 4 8t
2: vlan2: 0 8u
In my case everything is Gigabit, expect the direct attached printer.
With kind regards
Joe :cool:
knecke N66U problem with ethernet speed limited to 100 Mbps ASUS N Routers & Adapters 1
