How to configure N66U so that my access point will work
Abe911
The N66U is my main router/wireless, it is hardwired to an access point. This all worked until I did a firmware update last night. I can not figure out how to configure the N66U so that the access point will work, I've searched online and all I can find is how to configure the AP. The AP is a Unifi AP AC Pro.
Thank you for any help.
Abe
There are no specific settings on the N66U for attached access points. As far as the N66U is concerned the access point is indistinguishable from any other client device.
Thank you for that information! I thought that when I set it up a couple of years ago that there was a configuration required. I did a quick reset of the Unifi AP AC Pro and all is well.
Again Thanks!
