Hello,
I'm using my RT-AC68U in dual wan mode with dsl-modem as primary and lte usb stick als backup device (usb in android mode). So my configuration is dual wan enabled, failover mode with auto-fallback. This works perfectly, but after a reboot the usb modem is listed as "disconnected" and the router doesn't have an ip address on it's usb interface until it switches wan for the first time (which luckily happens very rarely).
Only if the modem was the active wan and then the router switched back to dsl usb's state changes to "standby", router has an ip address (always the same) on usb and I can connect to modems webgui from my lan clients (for this to work I insert one line with firewall start script: iptables -t nat -A POSTROUTING ! -s 192.168.0.153/32 -o usb0 -j MASQUERADE ).
What I want to do now is start the initial connection to the usb modem after a reload without the need to do a failover (unplug dsl) so that I can always reach the modems webgui right from the start.
Does anybody know how this could be done? Is there a command to trigger the usb from "disconnected" to "standby" state manually?
Thank you in advance,
regards,
Chris
regards,
Chris
