[How-To] Link Aggregation/LACP on RT-AC68U/W/R/P
  • Thread starter Thread starter Deleted member 28123
  • Start date Start date
D
Guest
Hello everyone -
I managed to get link aggregation working with the 68u router model and wanted to share my method in this how-to guide.
Environment
- Router Model: AC68U using ports 3 & 4
- Firmware: Asuswrt-Merlin 376.47 with JFFS enabed
- Switch: Netgear GSM7224R (including other 802.3ad capable switches)
- User Scripts (in /jffs/scripts/): firewall-start and services-start
Inspiration & Credits
- LinkAgg script by @KAD - http://forums.smallnetbuilder.com/showthread.php?t=12735
- DD-WRT forum post by @mrengles - http://www.dd-wrt.com/phpBB2/viewtopic.php?p=869756
Description
After several attempts (and many failures) to get link aggregation working using the LinkAgg script, I decided to further investigate the underlining cause for the failures and concluded:
1. LinkAgg, which has bugs, was designed to work with the 66u model which uses different internal switch port mappings (this was mentioned in several posts)
2. For some reason, Vlan 3 does not appear to work properly in the 68u model. This meant that I needed to use vlan 4 and vlan 5 instead.
3. The use of the xmit_hash_policy option and the corresponding switch/NAS hashing option was needed in order for link aggregation to work with a variety of switches & NAS boxes *new edit.
4. A simpler method was required to get link aggregation working across reboots and firmware updates.
Enough said - let's get to it ;)
First & Foremost - Backup your current nvram via the 'Administration - Restore/Save/Upload Setting' tab or nvram+jffs using @john9527 nvram save/restore utility @ http://smallnetbuilderforums.com/threads/user-nvram-save-restore-utility-r21.19521/
Step 1 - NVRAM Edits | Note: You will need to repeat this step if you clear the nvram ie. Beta to Final versions, resetting to Factory default
Apply the following changes to the router's nvram:
nvram set vlan4ports="3 5t"
nvram set vlan5ports="4 5t"
nvram set vlan4hwname=et0
nvram set vlan5hwname=et0
nvram commit
Step 2 - Create/Edit services-start script
Include the following code in services-start script located in /jffs/scripts/ (you will need to create this file from scratch, if you haven't done so already, with the right permissions)
#!/bin/sh
# Logger Services
logger -t "($(basename $0))" $$ SERVICES-START being started....
logger -t "($(basename $0))" $$ Bonding ports 3 and 4 commencing....
# Pre-Bonding
robocfg vlan 1 ports "1 2 5*"
# Bonding
sleep 2s
modprobe bonding
# Setting mode to 802.3ad
echo 802.3ad > /sys/class/net/bond0/bonding/mode
# Setting LACP rate to fast
echo fast > /sys/class/net/bond0/bonding/lacp_rate
# Setting MII monitoring interval to 50
echo 50 > /sys/class/net/bond0/bonding/miimon
# Setting xmit hash policy to layer3+4
echo 1 > /sys/class/net/bond0/bonding/xmit_hash_policy
ip link set bond0 up
echo +vlan4 > /sys/class/net/bond0/bonding/slaves
echo +vlan5 > /sys/class/net/bond0/bonding/slaves
brctl addif br0 bond0
# Post-Bonding
sleep 2s
logger -t "($(basename $0))" $$ Bonding Status....
cat /proc/net/bonding/bond0 | sed 's/^/+++  /' | logger
Step 3 - Create/Edit firewall-start script
Include the following code in firewall-start script located in /jffs/scripts/ (you will need to create this file from scratch, if you haven't done so already, with the right permissions)
#!/bin/sh
# Bonding IPtables rules
iptables -I INPUT -i vlan4 -j ACCEPT
iptables -I INPUT -i vlan5 -j ACCEPT
iptables -I INPUT -i bond0 -j ACCEPT
# Firewall/IPtables Performance Tweak for Bond0 to be placed right after the above bonding rules and before your custom rules - if any.
iptables -D INPUT `iptables --line-numbers -nL INPUT | grep ESTABLISHED | tail -n1 | awk '{print $1}'`
iptables -I INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
Step 4 - Set the switch's LAG hashing mode
This is the LAG config for the 2 switch ports you have connected to the router's port 3 and 4.
- Set the hashing mode to "Source/Destination MAC, VLAN, EtherType, source MODID/port" or the equivalent mode in your switch.
Step 5 - Reboot
You should now have link aggregation working with your 68u router and 802.3ad capable switch :)
This looks pretty clean. You should consider creating a Wiki entry for it.
I'll move your post to the Asuswrt-Merlin forum however, as this wouldn't work with stock firmware (no user scripts).
Thanks. I will post the wiki entry later today..
I am sure this method would work for 68u routers loaded with tomato/dd-wrt firmware with some minor edits to this guide, specifically NVRAM edits and scripts, which is why I posted it under ASUS Wireless/AC section of the forum.
How to: Enable root directory listing, rw rights?
Hi everyone,
I have just flashed my RT-N16 to the latest stable version (376.47).
Using Tomato Shibby earlier it was easy to config which directories of the router can be seen over FTP, even to give write permissions to them.
Now having this Merlin build -which is an absolute great custom firmware to my router - I have no idea what to do in order to have the router's root directories listed on an FTP client? How to give write permission to a given directory of the router?
Can anybody help me on this issue?
(Sorry if this is not the right thread for this issue, I just could not find any other suitable)
I'm not sure if Tomato has the bonding.ko kernel module included.
You are right. It was available on older versions of tomatousb but not anymore.
I updated the wiki entry for link aggregation on github and cleaned up the page a bit.
Thanks a lot! :D
But one more thing...
If I plug another cable in port 1 or 2 it seems that I'm unable to access the device from the wireless connection...
And if I reboot the router with only the port 3 and 4 connected it's working...
Any idea way? :confused:
Hello
I've tried it with following environment:
- Router Model: AC87U using ports 3 & 4 (Physical LAN Port 1 & 2)
- Firmware: Asuswrt-Merlin 376.49_4 with JFFS enabed
- Counterpart: Synology DS412+ (DSM 5.1-5021 Update 2)
This is the original configuration of the Router.
boss@RT-AC87U:/# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:0b:00:00:ad:d0
Port 1:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 2:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:11:32:25:0d:78
Port 4:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 54:a0:50:e5:1e:f8
VLANs: BCM5301x enabled mac_check mac_hash
   1: vlan1: 1 2 3 5 8t
   2: vlan2: 0 8t
1045: vlan1045: 4 7t
1046: vlan1046: 0 5 8t
1047: vlan1047: 1 3 5 8t
1099: vlan1099: 1t 2 4t 8u
1100: vlan1100: 0 2t 3 4 8u
1101: vlan1101: 0t 2 4 7t
1102: vlan1102: 0 3t 7 8t
1103: vlan1103: 0 3 7t 8u
boss@RT-AC87U:/# brctl show
bridge name	bridge id		STP enabled	interfaces
br0		8000.54a050e51ef8	yes		vlan1
							eth1
boss@RT-AC87U:/# cat /proc/net/vlan/config
VLAN Dev name	 | VLAN ID
Name-Type: VLAN_NAME_TYPE_PLUS_VID_NO_PAD
vlan1          | 1  | eth0
vlan2          | 2  | eth0
boss@RT-AC87U:/# ifconfig | grep Link
br0        Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
br0:0      Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
eth0       Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
eth1       Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
lo         Link encap:Local Loopback
vlan1      Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
vlan2      Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
boss@RT-AC87U:/# nvram show | sort | grep vlan
size: 42392 bytes (23144 left)
lan_ifnames=vlan1 eth1 wifi0
landevs=vlan1 wl0
vlan1hwname=et1
vlan1ports=1 2 3 5 7*
vlan2hwname=et1
vlan2ports=0 7
wan0_gw_ifname=vlan2
wan0_ifname=vlan2
wan_ifnames=vlan2
wandevs=vlan2
wl0_vlan_prio_mode=off
wl1_vlan_prio_mode=off
wl_vlan_prio_mode=off
The both Cables from the DiskStation are connected to physical Port 1 & 2 which are mapped to port 3 & 5. For any reason the roboctl command doesn't show the "Port 4" correctly...
based on your tutorial and the original configuration I've tried it manually with following commands (the LinkAgg script was not working). I've added the commands to create the vlans otherwise it fails to add the (not existing) vlan to the bond0.
boss@RT-AC87U:/# nvram set vlan103ports="3 8t"
boss@RT-AC87U:/# nvram set vlan104ports="5 8t"
boss@RT-AC87U:/# nvram set vlan103hwname=et0
boss@RT-AC87U:/# nvram set vlan104hwname=et0
boss@RT-AC87U:/# nvram commit
boss@RT-AC87U:/# robocfg vlan 1 ports "1 2 8t"
boss@RT-AC87U:/# modprobe bonding
boss@RT-AC87U:/# echo 802.3ad > /sys/class/net/bond0/bonding/mode
boss@RT-AC87U:/# echo fast > /sys/class/net/bond0/bonding/lacp_rate
boss@RT-AC87U:/# echo 100 > /sys/class/net/bond0/bonding/miimon
boss@RT-AC87U:/# echo 1 > /sys/class/net/bond0/bonding/xmit_hash_policy
boss@RT-AC87U:/# ip link set bond0 up
boss@RT-AC87U:/# echo +vlan103 > /sys/class/net/bond0/bonding/slaves
echo: write error: No such device
boss@RT-AC87U:/# vconfig add eth0 103
boss@RT-AC87U:/# echo +vlan104 > /sys/class/net/bond0/bonding/slaves
boss@RT-AC87U:/# vconfig add eth0 104
boss@RT-AC87U:/# brctl addif br0 bond0
boss@RT-AC87U:/# iptables -I INPUT 1 -i vlan103 -j ACCEPT
boss@RT-AC87U:/# iptables -I INPUT 1 -i vlan104 -j ACCEPT
boss@RT-AC87U:/# iptables -I INPUT 1 -i bond0 -j ACCEPT
the new configuration is the following:
Switch: enabled
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:11:32:25:0d:77
   1: vlan1: 1 2 8t
   2: vlan2: 0 8t
							eth1
							bond0
vlan1          | 1  | eth0
vlan2          | 2  | eth0
vlan103        | 103  | eth0
vlan104        | 104  | eth0
bond0      Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
vlan103    Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
vlan104    Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
size: 42464 bytes (23072 left)
landevs=vlan1 wl0
vlan103hwname=et0
vlan103ports=3 8t
vlan104hwname=et0
vlan104ports=5 8t
vlan1hwname=et1
vlan2hwname=et1
vlan2ports=0 7
wan0_ifname=vlan2
wan_ifnames=vlan2
wandevs=vlan2
boss@RT-AC87U:/# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.0 (June 2, 2010)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer3+4 (1)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: fast
Aggregator selection policy (ad_select): stable
Active Aggregator Info:
	Aggregator ID: 1
	Number of ports: 1
	Actor Key: 5
	Partner Key: 1
	Partner Mac Address: 00:00:00:00:00:00
Slave Interface: vlan103
MII Status: up
Link Failure Count: 0
Permanent HW addr: 54:a0:50:e5:1e:f8
Aggregator ID: 1
Slave queue ID: 0
Slave Interface: vlan104
MII Status: up
Aggregator ID: 2
Slave queue ID: 0
I've also tried to add the new vlans to the switch config, with following commands:
boss@RT-AC87U:/# robocfg vlan 103 ports "3 8t"
boss@RT-AC87U:/#robocfg vlan 104 ports "5u 8t"
Switch: enabled
Port 3: 1000FD enabled stp: none vlan: 103 jumbo: off mac: 00:11:32:25:0d:77
   1: vlan1: 1 2 8t
   2: vlan2: 0 8t
 103: vlan103: 3 8t
 104: vlan104: 5 8t
1047: vlan1047: 1 2 3 5 7t 8t
1100: vlan1100: 3 4 8t
1102: vlan1102: 0 1 7
1103: vlan1103: 0 1t 3 7t 8u
Bus this was also not working :(
The bond configuration on the DiskStation:
DiskStation> cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Transmit Hash Policy: layer2 (0)
MII Status: up
Up Delay (ms): 100
Down Delay (ms): 0
802.3ad info
LACP rate: fast
Min links: 0
	Aggregator ID: 2
	Number of ports: 1
	Actor Key: 17
	Partner Key: 1
Slave Interface: eth0
Speed: 1000
Duplex: full
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 2
Permanent HW addr: 00:11:32:25:0d:77
Aggregator ID: 1
Slave queue ID: 0
Slave Interface: eth1
Speed: 1000
Duplex: full
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 1
Permanent HW addr: 00:11:32:25:0d:78
Aggregator ID: 2
Slave queue ID: 0
DiskStation>
From my point of view the configuration looks okay. But the DiskStation is not reachable (e.g. ping IP) with this configuration. I couldn't find and useful log-information. Thus I haven't any Idea to proceed :(
Can you give me any hint? Please!!!
Kind Regards Tino
There are a couple of issues with your config but let us first get some additional details -
what's the output of ifconfig?
...couple of issues...
Oh, what a blame. I'm looking forward to know them :)
the original ifconfig (after reboot) is:
boss@RT-AC87U:/# ifconfig -a
aux0       Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
           BROADCAST MULTICAST  MTU:1500  Metric:1
           RX packets:250 errors:0 dropped:0 overruns:0 frame:0
           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:25213 (24.6 KiB)  TX bytes:0 (0.0 B)
           Interrupt:180 Base address:0x5000
           inet addr:10.1.60.1  Bcast:10.1.60.255  Mask:255.255.255.0
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:20743 errors:0 dropped:0 overruns:0 frame:0
           TX packets:20378 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:0
           RX bytes:1669807 (1.5 MiB)  TX bytes:12968782 (12.3 MiB)
           inet addr:169.254.39.123  Bcast:169.254.39.255  Mask:255.255.255.0
           RX packets:26183 errors:0 dropped:0 overruns:0 frame:0
           TX packets:21961 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:7550971 (7.2 MiB)  TX bytes:7961272 (7.5 MiB)
           Interrupt:181 Base address:0x6000
           RX packets:19560 errors:0 dropped:0 overruns:0 frame:2700
           TX packets:16946 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:3675544 (3.5 MiB)  TX bytes:13781858 (13.1 MiB)
           Interrupt:163
           inet addr:127.0.0.1  Mask:255.0.0.0
           UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
           RX packets:145 errors:0 dropped:0 overruns:0 frame:0
           TX packets:145 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:17946 (17.5 KiB)  TX bytes:17946 (17.5 KiB)
           RX packets:9871 errors:0 dropped:0 overruns:0 frame:0
           TX packets:11105 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:563195 (549.9 KiB)  TX bytes:5300830 (5.0 MiB)
           inet addr:80.109.113.143  Bcast:80.109.113.255  Mask:255.255.255.0
           RX packets:8961 errors:0 dropped:0 overruns:0 frame:0
           TX packets:2483 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:1208752 (1.1 MiB)  TX bytes:318108 (310.6 KiB)
and after the configuration described above:
           UP BROADCAST RUNNING MASTER MULTICAST  MTU:1500  Metric:1
           RX packets:0 errors:0 dropped:0 overruns:0 frame:0
           TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:0 (0.0 B)  TX bytes:3632 (3.5 KiB)
           RX packets:77262 errors:0 dropped:0 overruns:0 frame:0
           TX packets:58137 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:8990133 (8.5 MiB)  TX bytes:24832735 (23.6 MiB)
           RX packets:583347 errors:0 dropped:0 overruns:0 frame:0
           TX packets:226792 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:231605713 (220.8 MiB)  TX bytes:42088122 (40.1 MiB)
           RX packets:193286 errors:0 dropped:0 overruns:0 frame:280231
           TX packets:191623 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:34326575 (32.7 MiB)  TX bytes:214267467 (204.3 MiB)
           Interrupt:163
           RX packets:2074 errors:0 dropped:0 overruns:0 frame:0
           TX packets:2074 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:254622 (248.6 KiB)  TX bytes:254622 (248.6 KiB)
           RX packets:35261 errors:0 dropped:0 overruns:0 frame:0
           TX packets:39368 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:2510544 (2.3 MiB)  TX bytes:9434104 (8.9 MiB)
           UP BROADCAST RUNNING SLAVE MULTICAST  MTU:1500  Metric:1
           TX packets:47 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:0 (0.0 B)  TX bytes:3376 (3.2 KiB)
           TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:0 (0.0 B)  TX bytes:256 (256.0 B)
           inet addr:80.109.97.157  Bcast:80.109.97.255  Mask:255.255.255.0
           RX packets:390338 errors:0 dropped:0 overruns:0 frame:0
           TX packets:44761 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:31820688 (30.3 MiB)  TX bytes:6221196 (5.9 MiB)
Looking at the interfaces assigned to your br0 bridge and to avoid a potential misconfiguration due to the strange port mappings with the 87u (which I don't have), you will need to carry out the following changes:
Connect cable 1 and 2 to physical ports 1 and 2 of the router and bonding ports of your DiskStation
nvram set vlan103ports="1 8t"
nvram set vlan104ports="2 8t"
nvram set vlan103hwname=et1
nvram set vlan104hwname=et1
nvram commit
robocfg vlan 1 ports "3 5 8*"
modprobe bonding
- Retain your current iptables/bonding specific rules.
- Do not run 'vconfig add eth0 103' or 'vconfig add eth0 104'..
- Reboot.
As for your DiskStation (which I also don't have) - you will need to change the transmit hash policy from layer2 (0) to layer3+4 (1) by running:
Note: The above relative path may not be the correct path to your xmit_hash_policy file on your NAS. If this is the case, then search for that file, amend the relative path and apply. This change needs to be applied every time you reboot your NAS so make sure to add it to your start-up script/s.
The above approach/solution should work. Also, please include the output of ifconfig, robocfg show, nvram show | grep vlan, cat /proc/net/bonding/bond0 and remove any references to your public ip.
Thanks a lot for your response!
It fails when I try to add the vlans to the bonding/slaves.
boss@RT-AC87U:/tmp/home/root# echo +vlan103 > /sys/class/net/bond0/bonding/slaves
boss@RT-AC87U:/tmp/home/root# echo +vlan104 > /sys/class/net/bond0/bonding/slaves
I've changed the nvram settings and rebooted the router.
From my point of view it makes sense because the vlans 103 & 104 doesn't exist, am I wrong?
boss@RT-AC87U:/tmp/home/root# cat /proc/net/vlan/config
vlan1          | 1  | eth0
vlan2          | 2  | eth0
With this configuration the physical ports 3 & 4 stopped working ( I assume as a result of the robocfg command). I'm confused about port numbers used within the different tools, I assumed following mapping:
physical  |  nvram  |  robocfg
     1*   |    5    |     5
     2*   |    3    |     3
     3    |    2    |     2
     4    |    1    |     1
*connected to my DiskStation
My understanding is to remove the ports "to bond" from the vlan1 with the robocfg command. Thus the first command should be (Am I wrong?):
robocfg vlan 1 ports "1 2 8*"
Is the hash policy "layer 3+4" mandatory? It sould also work if both sides are configured with "layer 2". Because based on the documentation "layer 3+4" is not fully 802.3ad compliant.
Please find below the requested information:
bond0      Link encap:Ethernet  HWaddr 00:00:00:00:00:00
           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
           RX packets:562635 errors:0 dropped:0 overruns:0 frame:0
           TX packets:378715 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:53639894 (51.1 MiB)  TX bytes:98803686 (94.2 MiB)
           RX packets:48430 errors:0 dropped:0 overruns:0 frame:0
           TX packets:42735 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:18977404 (18.0 MiB)  TX bytes:12895732 (12.2 MiB)
           RX packets:578320 errors:0 dropped:0 overruns:0 frame:15611
           TX packets:386588 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:67534065 (64.4 MiB)  TX bytes:114364469 (109.0 MiB)
           Interrupt:163
           TX packets:250 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:34714 (33.9 KiB)  TX bytes:34714 (33.9 KiB)
           RX packets:10338 errors:0 dropped:0 overruns:0 frame:0
           TX packets:11816 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:584346 (570.6 KiB)  TX bytes:5464945 (5.2 MiB)
           inet addr:80.xxx.xxx.xxx  Bcast:80.xxx.xxx.255  Mask:255.255.255.0
           RX packets:15209 errors:0 dropped:0 overruns:0 frame:0
           TX packets:5077 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:1790637 (1.7 MiB)  TX bytes:699911 (683.5 KiB)
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:01:5c:31:3f:4c
   1: vlan1: 3 5 8t
   2: vlan2: 0 8t
1103: vlan1103: 0 1t 3 5t 7t 8u
size: 42807 bytes (22729 left)
landevs=vlan1 wl0
vlan103hwname=et1
vlan103ports=1 8t
vlan104hwname=et1
vlan104ports=2 8t
vlan1hwname=et1
vlan2hwname=et1
vlan2ports=0 7
wan0_ifname=vlan2
wan_ifnames=vlan2
wandevs=vlan2
MII Status: down
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: fast
bond bond0 has no active aggregator
Thank you for your effort!
The vlans are meant to be created at boot time by the router and not manually. I ran into the exact same issue with vlan3 which I noted in my first post. In your case, the 87u has 2 internal switches 7 and 8 - I believe this has something to do with the quantenna technology.
Try:
nvram unset vlan103ports
nvram unset vlan104ports
nvram unset vlan103hwname
nvram unset vlan104hwname
nvram set vlan101ports="1 7t"
nvram set vlan102ports="2 7t"
nvram set vlan101hwname=et1
nvram set vlan102hwname=et1
nvram commit
modprobe bonding
echo 0 > /sys/class/net/bond0/bonding/xmit_hash_policy
echo +vlan101 > /sys/class/net/bond0/bonding/slaves
echo +vlan102 > /sys/class/net/bond0/bonding/slaves
With your 87u, the physical port mappings are (from the default config you provided):
0 (WAN)    |     0     |     0
      1*   |     1     |     1
      2*   |     2     |     2
      3    |     3     |     3
      4    |     x     |     4
x=unknown
Port 4 is assigned to:
In order to avoid any further complications with your setup, your bonding port options are combinations 1 & 2, 2 & 3 or 1 & 3 until someone figures out the proper mappings for ports 4 and 5. 7 and 8 are the internal switches.
For robocfg usage, you need to unassign/unmap the port/s used for bonding from vlan1 as they are being assigned/mapped to other vlan/s.
As for the hashing policy, you can choose whichever policy you prefer just as long as they match at both ends ie. router + diskstation. I ran into issues with layer 2 in my switched network where devices connected to the switches were not communicating with the router.
Should the above config fails, try the following as well:
nvram unset vlan101ports
nvram unset vlan102ports
nvram unset vlan101hwname
nvram unset vlan102hwname
nvram set vlan4ports="1 7t"
nvram set vlan5ports="2 7t"
nvram set vlan4hwname=et1
nvram set vlan5hwname=et1
nvram commit
modprobe bonding
Reboot.
Hello AtAM1,
the first success :)
After some testing and "reverse engineering" of the port mapping within the robocfg command I've found out the port mapping:
 physical | robocfg
     1    |    5
     2    |    3
     3*   |    2
     4*   |    1
    WAN   |    0
   WLAN   |    8
# more details in attached RT-AC87U_robocfg_ports.txt.zip
With some further tests I've found out that vlan ID's with more than 2 digits are not created automatically after reboot. Thus I've used following code:
# NVRAM edits
nvram set vlan11ports="1 7*"
nvram set vlan12ports="2 7*"
nvram set vlan11hwname=et1
nvram set vlan12hwname=et1
nvram commit
# remove ports used for aggregation
robocfg vlan 1 ports "3 5u 8t"
modprobe bonding
echo +vlan11 > /sys/class/net/bond0/bonding/slaves
echo +vlan12 > /sys/class/net/bond0/bonding/slaves
# Firewall rules
iptables -I INPUT 1 -i vlan11 -j ACCEPT
iptables -I INPUT 1 -i vlan12 -j ACCEPT
Configuration Result:
           UP BROADCAST RUNNING PROMISC MASTER MULTICAST  MTU:1500  Metric:1
           RX packets:30875 errors:0 dropped:0 overruns:0 frame:0
           TX packets:64960 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:4912603 (4.6 MiB)  TX bytes:18287977 (17.4 MiB)
           inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
           RX packets:102762 errors:0 dropped:0 overruns:0 frame:0
           TX packets:74430 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:12252659 (11.6 MiB)  TX bytes:31010557 (29.5 MiB)
           RX packets:1467492 errors:0 dropped:0 overruns:0 frame:0
           TX packets:509146 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:1664415357 (1.5 GiB)  TX bytes:143765693 (137.1 MiB)
           RX packets:404649 errors:0 dropped:0 overruns:0 frame:1290392
           TX packets:1297193 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:113750251 (108.4 MiB)  TX bytes:1649588624 (1.5 GiB)
           Interrupt:163
           RX packets:6464 errors:0 dropped:0 overruns:0 frame:0
           TX packets:6464 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:1020628 (996.7 KiB)  TX bytes:1020628 (996.7 KiB)
           RX packets:45536 errors:0 dropped:0 overruns:0 frame:0
           TX packets:56807 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:7902047 (7.5 MiB)  TX bytes:13064868 (12.4 MiB)
vlan11     Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
           RX packets:25684 errors:0 dropped:0 overruns:0 frame:0
           TX packets:60214 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:3584158 (3.4 MiB)  TX bytes:17459136 (16.6 MiB)
vlan12     Link encap:Ethernet  HWaddr 54:A0:50:E5:1E:F8
           RX packets:5191 errors:0 dropped:0 overruns:0 frame:0
           TX packets:4746 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:1328445 (1.2 MiB)  TX bytes:828841 (809.4 KiB)
           RX packets:178290 errors:0 dropped:0 overruns:0 frame:0
           TX packets:41824 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:22595137 (21.5 MiB)  TX bytes:6126334 (5.8 MiB)
Switch: enabled
Port 1: 1000FD enabled stp: none vlan: 11 jumbo: off mac: 08:00:27:d2:bd:02
Port 2: 1000FD enabled stp: none vlan: 12 jumbo: off mac: 08:00:27:d2:bd:01
Port 3:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:62:6e:4e:4e:03
   1: vlan1: 3 5 8t
   2: vlan2: 0 8t
  11: vlan11: 1 8t
  12: vlan12: 2 8t
size: 43295 bytes (22241 left)
landevs=vlan1 wl0
vlan11hwname=et1
vlan11ports=1 7*
vlan12hwname=et1
vlan12ports=2 7*
vlan1hwname=et1
vlan2hwname=et1
vlan2ports=0 7
wan0_ifname=vlan2
wan_ifnames=vlan2
wandevs=vlan2
vlan1          | 1  | eth0
vlan2          | 2  | eth0
vlan11         | 11  | eth0
vlan12         | 12  | eth0
							eth1
							bond0
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: fast
	Aggregator ID: 1
	Number of ports: 1
	Actor Key: 5
	Partner Key: 1
Slave Interface: vlan11
MII Status: up
Aggregator ID: 2
Slave queue ID: 0
Slave Interface: vlan12
MII Status: up
Aggregator ID: 1
Slave queue ID: 0
In order to facilitate the error analysis I've set up a Virtual Machine (ubuntu) with the same bonding configuration as the DiskStation have.
- bond between VM & DiskStaion was working fine
- bond between Router and Virtual Machine worked only in one direction. I'm able to ping the router (192.168.1.1) and google (8.8.8.8) from the VirtualMachine. But the Router is not able to ping the VirtualMachine (192.168.1.111).
boss@RT-AC87U:/# traceroute 192.168.1.111
traceroute to 192.168.1.111 (192.168.1.111), 30 hops max, 38 byte packets
 1  *  *  router.asus.com (192.168.1.1)  3001.175 ms !H
 2  router.asus.com (192.168.1.1)  3009.634 ms !H  3009.781 ms !H  3009.885 ms !H
I've activated the logging of the FW but I can't see any DROPED packets.
Do you have any idea what could be the reason? Any route missing
bond status on VirtualMachine:
root@web-test:/# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: fast
	Aggregator ID: 9
	Number of ports: 1
	Actor Key: 17
	Partner Key: 1
Slave Interface: eth3
MII Status: up
Permanent HW addr: 08:00:27:d2:bd:01
Aggregator ID: 9
Slave Interface: eth4
MII Status: up
Permanent HW addr: 08:00:27:d2:bd:02
Aggregator ID: 10
Thanks a lot for your valuable support!
Kind Regards Tino
I am really confused. This sounds exactly like what I am trying to do but have no idea about any of what you guys are talking about.
I have the RT-AC87U and a DIY FreeNAS box with dual lan. I have the 2 ethernets connected to ports 1 and 2 on the router as those are marked teaming. I setup Link Aggregation on the FreeNAS box as LACP and everything seems fine except there is only traffic on the first ethernet which I assume is because I never did anything on the router side.
What exactly do I need to do to setup port 1 and 2 to support this LACP link?
@pjalm: could you post the bond configuration of your NAS Box?
Log in (telnet or ssh) to your NAS and issue following command:
I've used the physical LAN Ports 3 & 4 on the RT-AC87U, because the internal mapping of Port 1 & 2 is a bit confusing.
But the LinkAggregation is not running fine until now, it works just in one direction (may be an routing issue).
Regards Tino
It's not a routing issue. You have a failure with the second link when connecting your VM to the router. Your VM's bond driver is outdated too - check the dates.
You need to focus on achieving a working link aggregation between your router and diskstation first.
Try the following and provide feedback with physical ports 1 & 2 and ports 3 & 4 of the router connected to the DiskStation and with layer3+4 applied on both devices:
# NVRAM edits
nvram commit
robocfg vlan 1 ports "3 5 8t"
modprobe bonding
# Firewall rules
In your default robocfg output, vlan 1 is assigned ports 1 2 3 5 8t - notice here 5 and not 5u.
Also try physical ports 2 & 3 and remember to apply the correct nvram values and reboot ie.
# NVRAM edits
nvram set vlan11ports="2 7*"
nvram set vlan12ports="3 7*"
nvram commit
robocfg vlan 1 ports "1 5 8t"
Whoever was responsible for the port mappings must have been boozing it while coding / architecting the ports and their internal mappings... what a mess!
Hello AtAM1,
the reason why I've used "5u" at the robocfg vlan config is the following:
# results to following vlan1 configuration at robocfg show (port 5 is tagged)
   1: vlan1: 3 5t 8t
# results to following vlan1 configuration at robocfg show (port 5 is untagged)
   1: vlan1: 3 5 8t
# this is the 'help' output of the robocfg command
Broadcom BCM5325/535x/536x/5311x switch configuration utility
BCM5301x partial support added by Eric Sauvageau
Copyright (C) 2005-2008 Oleg I. Vdovikin (oleg@cs.msu.su)
Copyright (C) 2005 Dmitry 'dimss' Ivanov of "Telecentrs" (Riga, Latvia)
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
Usage: robocfg <op> ... <op>
Operations are as below:
        show -- show current config
        showports -- show only port config
        showmacs -- show known MAC addresses
        switch <enable|disable>
        port <port_number> [state <enabled|rx_disabled|tx_disabled|disabled>]
                [stp none|disable|block|listen|learn|forward] [tag <vlan_tag>]
                [media auto|10HD|10FD|100HD|100FD|1000HD|1000FD]
                [mdi-x auto|on|off] [jumbo off|on]
        vlan <vlan_number> [ports <ports_list>]
        vlans <enable|disable|reset>
        ports_list should be one argument, space separated, quoted if needed,
        port number could be followed by 't' to leave packet vlan tagged (CPU
        port default) or by 'u' to untag packet (other ports default) before
        bringing it to the port, '*' is ignored
Samples:
1) ASUS WL-500g Deluxe stock config (eth0 is WAN, eth0.1 is LAN):
robocfg switch disable vlans enable reset vlan 0 ports "0 5u" vlan 1 ports "1 2 3 4 5t" port 0 state enabled stp none switch enable
2) WRT54g, WL-500g Deluxe OpenWRT config (vlan0 is LAN, vlan1 is WAN):
robocfg switch disable vlans enable reset vlan 0 ports "1 2 3 4 5t" vlan 1 ports "0 5t" port 0 state enabled stp none switch enable
I'll test your recommended configuration today or tomorrw evening.
Kind Regards Tino
Thanks for sharing your reasoning behind using 5u and not 5 ... I believe this is because port 5 is an internal switch which is why 5 results in 5t and 5u results in 5... hmmm, try the following making sure to unset any previous custom nvram/vlan settings and apply layer3+4 on the DiskStation:
# NVRAM edits
nvram commit
robocfg vlan 1 ports "1 5u 8t"
modprobe bonding
# Firewall rules
If the above doesn't work, I don't know what will. It doesn't help that I don't have the 87u to experiment with/analyze.
I am also not sure if my robocfg/nvram output maybe of any help to you but I will include it anyway"
[B]ROBOCFG[/B]
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Mon Jan 12 10:06:10 UTC 2015
admin@gateway:/tmp/home/root# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: XX:XX:XX:XX:XX:XX
Port 3: 1000FD enabled stp: none vlan: 13 jumbo: off mac: XX:XX:XX:XX:XX:XX
Port 4: 1000FD enabled stp: none vlan: 14 jumbo: off mac: XX:XX:XX:XX:XX:XX
Port 8:   DOWN enabled stp: none vlan: 2 jumbo: off mac: 00:00:00:00:00:00
   1: vlan1: 1 2 5t
   2: vlan2: 0 5
  13: vlan13: 3 5t
  14: vlan14: 4 5t
  56: vlan56: 1 2t 3 4
  57: vlan57: 0t 3t 4 7 8t
  58: vlan58: 1t 2 4t 5t 7
  59: vlan59: 0t 1t 2 3t 5t
  60: vlan60: 5t 7
  61: vlan61: 8u
  62: vlan62: 1t 2t 3t 4 7
[B]NVRAM[/B]
admin@gateway:/tmp/home/root# nvram show | grep vlan
vlan14ports=4 5t
vlan2ports=0 5u
vlan13hwname=et0
vlan2hwname=et0
lan_ifnames=vlan1 eth1 eth2 wl0.1 wl0.2
vlan13ports=3 5t
vlan1hwname=et0
vlan1ports=1 2 3 4 5*
landevs=vlan1 wl0 wl1
vlan14hwname=et0
