I ordered two ASUS RT-AC88U routers and I will be connecting both of them to my modem via Ethernet cables.
The routers will be on separate floors.
I couldn't find complete information how to properly set them up. From my understanding I should
do the following:
Modem:
-Set IP for example 192.168.1.1 and turn on DHCP with a range 192.168.1.4-192.168.1.xxx
Router One:
-Set IP 192.168.1.2 and turn off DHCP
Router Two:
-Set IP 192.168.1.3 and turn off DHCP
In other words, let the modem assign IP's (by having DHCP on), and set IP addresses of both routers
to be outside the DHCP range.
Now what about NAT?
Also I never owned such advanced routers before, should I set them up in some specific mode (bridge mode?).
P.S. I'll be installing Merlin firmware.
Thank you
do the following:
Modem:
Router One:
Router Two:
Now what about NAT?
Thank you
