If I install Transmission as documented at https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware , it looks like after router restart, Transmission starts before the clock gets adjusted by NTP, which results in Transmission running in GMT zone. Is there a way to configure startup scripts so that Transmission starts after NTP has adjusted the clock?
(I already posted about this problem here, but solution was not found; thanks to x190 at https://forum.transmissionbt.com/viewtopic.php?f=8&t=17283&p=71722#p71722 for the idea)
