httpd dying
Zigster
Hello Forum,
there's a feature in the current Merlin Firmware 378.56_2 for the Asus RT-N66U, that allows to assign a common name for devices identified by their MAC-Adress in the Device List section:
Main "Overview" -> "Device List" -> Click on the Mac Adress in the "Client Name" Column to change the Mac-Adress to a more recognizable name and click outside of the field to save that name.
Just recently I noticed, that I can't use that feature anymore, because as soon as I try to alter and save the another string in the text field, the httpd process dies immediately and the watchdog respawns the httpd (with a new pid). As a result the web interface user is put on the login screen of the routers web interface.
Tried with several browsers, operating systems and devices.
Can anyone confirm that behavior or provide a remedy for this problem ?
Thanks for info
Zigster
Hello Forum,
Thanks for info
Zigster
I had this problem and it fixed itself when I rebooted. If you can't for merlin's firmware the offical FW is out with the fix.
https://www.asus.com/us/Networking/RTN66U/HelpDesk_Download/
ASUS RT-N66U Firmware version 3.0.0.4.378.9383
http://dlcdnet.asus.com/pub/ASUS/wireless/DSL-N66U/FW_RT_N66U_30043789383.zip
Hi snakebite3,
rebooting didn't help, I tried that a couple of times.
Hmm, I'd rather stick to merlin's FW, but will Merlin provide a fix for this?
Thanks for Info.
Zigster
@altstadt & @snakebite3
Thanx for your Info...just updated the Firmware.
Problem is only partially solved:
The Client-Name now shows the correct Manufacturer String, but altering the Name still causes the httpd to die...
Hope, that will be fixed soon...
Thanx,
Zigster
UPDATE:
After a couple of reboots, the problem just went away... I was able to successfully apply the changes to the Client Name...strange, but hey it works!
Zigster
