So I've finally forayed into getting some moca devices and they are as plug and play as powerline, but with superior speeds. And they can be dirt cheap by comparison if you're looking one step below bonded 2.0.
Here's what I've found that's a bargain:
$10 new - https://www.amazon.com/dp/B00FKTMWDE/?tag=snbforums-20
I haven't used these personally as of yet, but they are the cheapest units that will transfer at 500Mbps real-time (I found iperf tests online), have a dual band AP built-in, and has 2 ethernet ports, which I believe are gigabit. A set of these is only $20, which blows any powerline solution (and almost any other solution) out of the water since it's 500Mbps.
$45 used with 60-day warranty - https://www.ebay.com/itm/Frontier-G...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
These are the exact units I purchased and they got a 600Mbps link and I was able to get right under 500Mbps iperf results. They also have a dual band AP built-in as well as a 4-port gigabit switch. These are also routers, so you have to disable that stuff if you just want them to be adapters and APs, but it's not too bad to do so.
There are a few other companies and adapters out there like the deca ones that may be just as cheap, but they're usually only limited to Moca 1.0/1.1 speeds. By far, the two above are the most bang for the buck I've seen. You literally can outfit every room of your house with wifi and an Ethernet port for $10/room.
Hope this helps someone out there!
