Install Download Master as an Entware package
Carlos M.
I installed succesfully owncloud and discovered that if I install, after, DM... I overwrite "something" of the owncloud config and everything stops working. So... I decided to keep owncloud and search a DM sustitute.
I installed pyload but don't do that I look for and DM was perfect for this. Just send from my firefox some torrent links to queue the downloads in my router.
So... I would like to install DM from the cli and have the control about whats happen during the installation.
For DM I use the Asus Downloader pluging for firefox and for pyload I use FlashGot but... won't work.
Any idea about how can I do it?
Thanks in advance
Edited:
I am newbie with linux and this firmwares... I suspect that is not possible to have entware-ng and optware-ng running together... :(
I'll remove entware and try to install optware-ng with lighttpd, owncloud and donwload master.
Any suggestion?
Transmission is the one you are looking for.
Thanks flytiger. I'm not sure about your advice but I'll check the addons for FF and this downloader manager.
I want automate my workflow with the router and torrent downloading.
I hope this works perfectly with entware-ng.
Just a question, what's better, Transmission or RUtorrent?
