Install firmware from multiple zipfiles?
Cugel
Hello,
I recently downloaded the rmerlin firmware. How does one install firmware from multiple zip files?
Also, it seems that the RT-AC66U_3.0.0.4_376.49_X.zip files have x=0, x=2, x=4 and x=5. No 1 or 3. Is this correct?
Many thanks.
Zip files are version of firmware, you extract one or all and use the .trx inside to update your router via GUI interface of router. (X meaning a version of that firmware) Allways you may upgrade original versions of Asus firmware.
These are not multi-part files, this is just the FW revision number.
Ahh.... that makes much more sense. The FW revision number was not apparent to me. Thanks so much for your hard work to provide the firmware to us all.
