I have an Intel X520-T2 NIC with a noisy fan. I've removed the fan, flipped it over and it is:
JARO
AD3212MB-K71
I've googled it and I get a bunch of random parts websites but no place where I can buy from.
Any ideas? Thanks!
Yep, big no-no. I researched fans and fan noise to death when I had a fan in an usb enclosure start to get noisy. It takes a few drops of 3n1 brand fan oil to keep it running perfect for 6months or so. Replacing the fan is not possible in this unit or I would have maybe done that.Do not use WD40 - and some fans lubricants are silicon based...
Bearing for a replacement I did not have (to extract the bearing does not know its size), lock ring removed (about 30 minutes), grease is applied to the inside of the bearing.Since you could take the bearing out, you could have just replace the bearing--and with one with removable shields so if it becomes a problem again, you can simply clean and re-lube the bearing.
Welcome To SNBForums
